Username: Oglejust Post Number: 188 Registered: Aug-06
Wednesday, October 04, 2006 - 02:06 GMT can you put a 2ohm load on 1 channel of a 2 channel amp and a 4ohm load on the other channel?
Username: Van_man Boston South,
MA
Post Number: 989 Registered: Mar-06
Wednesday, October 04, 2006 - 02:08 GMT try the amp section
Username: Oglejust Post Number: 189 Registered: Aug-06
Wednesday, October 04, 2006 - 02:10 GMT well this section gets more traffic
Username: Makmillion MN
United States
Post Number: 820 Registered: Apr-06
Wednesday, October 04, 2006 - 02:28 GMT Yes! you can.. but it's not safe :| What brand/model amp do you have?
Username: Oglejust Post Number: 191 Registered: Aug-06
Wednesday, October 04, 2006 - 02:32 GMT ummm well till i get the money for a new one... a profile usa baja ha 1000. its 160x2 @4ohms, 500x 2 @ 2ohms and 480bridged at 4ohms
Username: Dustin3 Tigard,
OR
U.S.
Post Number: 3784 Registered: Oct-05
Wednesday, October 04, 2006 - 02:37 GMT it would be fine if the amp can support it. think of each channel being seperate which the are. so in reality each channel can have a diff load on them cuz their seperate. im just takin a swing at this
MA
Post Number: 990 Registered: Mar-06
Wednesday, October 04, 2006 - 03:15 GMT I think it would just put a 6 ohm (3 per channel) load on the amp. So maybe 350 X 2 @ 3ohms. Not sure thou. What are you hooking up to it?
Username: Oglejust Post Number: 196 Registered: Aug-06
Wednesday, October 04, 2006 - 03:19 GMT ummm a 12in 4ohm dvc kicker cvr and a 10in mtx 4ohm svc 4000 series.
MA
Post Number: 991 Registered: Mar-06
Wednesday, October 04, 2006 - 03:33 GMT Run it like this bridged . I think this is a 4 ohm load.
Username: Oglejust Post Number: 197 Registered: Aug-06
Wednesday, October 04, 2006 - 03:36 GMT ok, i agree i believe its a 4ohm load. thanks
