Username: Bump05 Hesperia,
CA
Post Number: 124 Registered: Aug-06
Wednesday, September 27, 2006 - 18:47 GMT i can get this amp brand new for 4000 i will be getting it for 2 15" l7's is there an amp thats better for those subs for same price or cheaper thanks
CA
Post Number: 125 Registered: Aug-06
Wednesday, September 27, 2006 - 18:48 GMT ^^^ 400$ i mean
Username: Juliob Santo DomingoDominican Re...
Post Number: 2598 Registered: Dec-05
Wednesday, September 27, 2006 - 18:51 GMT hard to say... only autotek MM 2000d, but the soundstream is good BTW
Username: Troy81 Tavernier,
Fl
Us
Post Number: 1174 Registered: Mar-06
Wednesday, September 27, 2006 - 19:01 GMT you WILL be happy with ss, i ran one at .5 ohms for like 3 weeks and it only got a bit warm, i wouldnt reccomend doing that tho
CA
Post Number: 126 Registered: Aug-06
Wednesday, September 27, 2006 - 19:03 GMT i got a ROUSH ford focus zx3 i already build my box got my subs. and was prolly going to go with the soundstream, but when you guys say upgrade electric is it just the alternator, do i even need to, and is it hard to do it yourself thanks
Fl
Us
Post Number: 1175 Registered: Mar-06
Wednesday, September 27, 2006 - 19:05 GMT well, a ford focus yes youll have to get an alt for 2000rms, and really its just an alt and all bigger wiring coming off of it
Post Number: 2600 Registered: Dec-05
Wednesday, September 27, 2006 - 19:09 GMT and some batteries (yellow tops), isolator too
Fl
Us
Post Number: 1178 Registered: Mar-06
Wednesday, September 27, 2006 - 19:44 GMT you dont need batterys unless your gonna burp with the car off, it doesnt seem like you'll be doing comps so i wouldnnt worry about that
CA
Post Number: 127 Registered: Aug-06
Wednesday, September 27, 2006 - 21:40 GMT so the alternator will all i need where can i get one cheap and is it easy to install? thanks guys
Post Number: 2606 Registered: Dec-05
Wednesday, September 27, 2006 - 22:38 GMT cheap maybe... easy to install... hehe i doubt it. Search iraggi on ebay
Username: Moondogg1212 Post Number: 12 Registered: Aug-06
Friday, September 29, 2006 - 15:32 GMT usually the hardest part about changing alts is getting the belt back on if its a Roush its pretty new prob wont be too hard, just need a little bit of mechanical skill
Username: Rovin Trinidad & T...
Post Number: 9225 Registered: Jul-05
Saturday, September 30, 2006 - 14:54 GMT i would still rec putting @ least 1 more batt/dry cell ,remember in addition 2 2000wrms im guessing he will have @ least 300wrms more 4 mids/highs .....
Username: Extrmndor3 Chicago,
Ill
Us
Post Number: 1979 Registered: Feb-06
Saturday, September 30, 2006 - 18:48 GMT plz dont use an insulator
Username: Tweeker RE AUDIO
Post Number: 527 Registered: May-06
Saturday, September 30, 2006 - 20:46 GMT i can get yo a orion 2500d fro 400 NEW!
CA
Post Number: 128 Registered: Aug-06
Monday, October 02, 2006 - 18:55 GMT david how?
Username: Mixmastaspig Canada,
Post Number: 753 Registered: Sep-05
Wednesday, October 04, 2006 - 00:38 GMT As I would like to know as well David
