New member Username: HarsiratPost Number: 1 Registered: Oct-06 | I HAVE PANSAT 2500 WHICH I CLONED FROM FORTECH ULTRA... i was away for 6 months and right now i don't have any channels working.. i have figured out that i need to upload a new bin and then enter keys i guess.. can some one please help me on hw to upload the bin..?? i already have the bin buti can't open the file..and also wat keys do i need to enter once i upload the new bin.. please help m eout guyzzzzzzzz......... |
Bronze Member Username: FastbeatzPost Number: 41 Registered: Sep-06 | u need an uploader ..than hook up the cable from receiver to computer and once u get an uploader use it to download the bin in the receiver |
New member Username: HarsiratPost Number: 2 Registered: Oct-06 | where do i get the uploader?? n how do i download it.. i have the wire i neee... thankxxx |
Silver Member Username: Minn_rockPost Number: 376 Registered: Aug-06 | you need a loader too, to load your bin into your box,extract your bin files,turn off your box from the back connect your cables from pc to your box.load the bin into the loader, turn on your box from the back, the first green light u see from your box press download on your pc... |
New member Username: HarsiratPost Number: 3 Registered: Oct-06 | where do i get the loader?? |
Silver Member Username: Minn_rockPost Number: 377 Registered: Aug-06 | you can find bin,loader and keys in there.. |
Bronze Member Username: FastbeatzPost Number: 44 Registered: Sep-06 | so u technicall y have a fortec ultra box?? cuz i got the same thing than i caan explain more |
Bronze Member Username: FastbeatzPost Number: 45 Registered: Sep-06 | Hey friends, Some people are having problems loading the new bin into their Fortec Star Lifetime Ultra. If you're one of them, then please read everything that is below CAREFULLY. You need RS 232 female-female serical cable. (Straight Cable for Fortec Star Lifetime Ultra) Click on this link: How to load bin from your PC into your Fortec Lifetime Ultra: Open the loader and select the file that you downloaded from I'm telling you people to put "Pansat 2500" inside the STB Model area bcause if you put "Lifetime Ultra", it's not going to work. The information that is above, is for Fortec Star Lifetime Ultra receivers ONLY. If you're still having any kind of problems, please post them or email me. My email address is : asharfivig@msn.com Good Luck!>>>>>i took this from another thread |
New member Username: HarsiratPost Number: 4 Registered: Oct-06 | i had a fortec ultra but then i cloned it to pansat 2500... |
