Hey guys i connected the cable turned it on, opened the loader(1.4 and 3.38) but i tryed to load the bin but it sits on 0% for a while and then i got a msg saying "Write Failed"
First of all, for a 2700 the cable that you need is a null modem cable, the receiver must be on while trying to download, you must select comm1 at the PC and 115200 speed.
Which cable are you using and which bin are you trying to download???
I guess pantec 2500 uses a straight cable....for the 2700 you need a null modem cable, what you can do is go to Radio Shack and buy a null modem adapter, plug it into the cable you have and should work.....
I was able to upload the new bin for 2700e but the lights on the front of the receiver are acting like night rider i also was able to upload the main bin but always the same thing any idea????
Go to Pansatusa and get the factory bin for that receiver, download it using the loader that comes with the bin after that check that everything works properly, then using the same loader download the new bin...
