Changing Region on Jensen VM9311
Username: Mastelaro
Brazil
Please, how can a hack the region on the DVD Jensen VM9311. It is usually set up to region 1, I need it changed to 4, or better get it free region.
I appreciate everyone's help.
Username: Psychedelic_feta
Montreal, Quebec Canada
Post Number: 15
Diogo, check the code I posted in this section for Jensen units. Not only will it disable the parking brake, but also you can change the region code. Only thing is you can't DISABLE the region code, only change.
Hope this helps!
