What to tune it to?
Username: Bsman
Sarnia, Ontario Canada
Post Number: 13
Im wonderin what to tune an infinity 12 inch SVC 300rms to in like 2 or 3 cubes?
Username: Denali_on_22s
Maryville, TN Us
Post Number: 253
depends on whether you want low or loud bass... that infinity probably wont get very low so id tune it around 36-38, 40 for the most SPL
Username: Renegadesrun
Lafayette, IN US
Post Number: 124
FS of the sub?
Username: Bsman
Post Number: 14
ok so if i want it as low as i can get it i should try like 36?
Username: Bsman
Post Number: 15
FS?
Username: Bsman
Post Number: 16
Im reading the manual an it says i can tune it to 33 in 2 cubes
Lafayette, IN US
Post Number: 125
One of the "thiele small (t/s) parameters".
Roughly put its Resonant frequency... the frequency the subwoofer most easily resonates at and also a number which i would recommend not tuning below.
Which apparently is common in here as incorrect amp adjustment judging by the amount of subs that "knock" when putting the power to them.
Lafayette, IN US
Post Number: 126
When in doubt......follow the manual.
Username: Bsman
Post Number: 17
well, it says i cant tune it below 28 but it recommend tuning it in 2 cubes to 30 more like 33 i would think at least
Username: Bsman
Post Number: 18
is that what i should do??
Lafayette, IN US
Post Number: 128
32-35 IMO, are great for all around streat beating. In essence....I agree with the manual.
Username: Bsman
Post Number: 19
ok then thats what i will do thanks a lot for the help:-)
Username: Bayrent88
Ingleside, Texas USA
Post Number: 41
what is a good site to use for the calculate box ports
Username: Adddisorder
West palm, Florida
Post Number: 953
subwoofertools.com
