Username: Thumping_corsica Saginaw, miUnitd states
Post Number: 71 Registered: Aug-06
Wednesday, September 27, 2006 - 21:47 GMT i bought some duct insulation from home depot (a lot..says it will dampen) and im not sure how to install it.. it says its self adhesive? what this mean. thx
Username: Mixmastaspig Canada,
Post Number: 748 Registered: Sep-05
Wednesday, September 27, 2006 - 22:34 GMT it will stick all by its self, like tape I'd assume so you wouldnt need like glue to install it.
Post Number: 76 Registered: Aug-06
Wednesday, September 27, 2006 - 22:38 GMT but u see neither side sticks (the pink puffy stuff or the thin shiny paper like stuff.. or do i take this off?
Username: Cavsmaxima New York
United States
Post Number: 362 Registered: Aug-06
Thursday, September 28, 2006 - 02:26 GMT if it peels off then id think ud have to take it off. Is on side like fusion tape or double sided tape?
Post Number: 83 Registered: Aug-06
Saturday, September 30, 2006 - 00:37 GMT nevermind i got the wrong stuff from walmart; i went back and got the right stuff... works great for only 15 bucks muaha
Username: Tdawg30 Ohio
Post Number: 274 Registered: Jun-06
Saturday, September 30, 2006 - 16:14 GMT does it really work good? I got a wanting to go get a lot of it to put over my whole car.
Post Number: 89 Registered: Aug-06
Saturday, September 30, 2006 - 18:23 GMT yes. pretty damn good
