New member Username: BillyssmailToronto, ON Post Number: 7 Registered: Sep-06 | I have a DISH with one LNB pointing towards ECHO 7 119, if i install second LNB on the same dish (i have dual LNB option ) Can i get the BEV chennels with out changing direction of DISH ? IF yes then what sett i have to scan in Antinna Setup ? |
Silver Member Username: NikkPost Number: 169 Registered: Sep-06 | Bill.... BEV is at Nimiq1...far away from ECHO 7.....you need another dish..... |
Silver Member Username: NikkPost Number: 170 Registered: Sep-06 | Check here... http://www.lyngsat*.com/packages/america.html just take out the * after lyngsat |
New member Username: BillyssmailToronto, ON Post Number: 8 Registered: Sep-06 | thanks Nikk...i appreciate ! |
