How can i get 2 recievers working?
Username: Icekilla0388
Toronto, Ontario Canada
Post Number: 131
ok i have a pantec and a viewsat extreme, and 2 sats on my roof 119 and 61.5, i want to have both recievrs in different rooms and watching there own thing, like one can watch ppv other can watch international or something, WHAT CAN I DO?
Username: Mc_sunny
Post Number: 326
It is possible if you have enough outputs on your lnbs. You'll need dual lnb on your 119 dish and dual lnb on your 61.5 dish. a regular DiScQ switch should do. you'll need a switch for each receiver.
Post Number: 133
thanks but how would i install that? do u know a web site where they explain how to do it, thanks
Username: Mc_sunny
Post Number: 327
Shivas thats how i hooked up mine..Here is a diagram for you...i hope this help...Good luck
Username: Dxv1988
MA
Post Number: 62
Please help?
I bough a Viewsat Extreme and I am trying to download bin file DBPSW_060924AS_XTREME.PGM and SatInfo.sat by using Loader2, I have selected above 2 files and click PC->STB. The Loader2 is keep trying to send file calls ZRQINIT and resending, but never able to send or download the file. Can somebody pleases help?
Thank you in advance.
David
Post Number: 134
Thanks alot Mcsunny, i can install it now, greatly appreciated
Post Number: 135
David first take out the plug from the wall outlet, then click pc to stb then plug it back in, it should then send
Username: Dxv1988
MA
Post Number: 63
Thank you so much for your help Shivas! Its working now.
I appreciated very much, I mean it.
Username: Mph201
Post Number: 14
hey I have a question. What if you wanted to do the same thing that Shivas is doing but with three satellites. Is it still possible?
Username: Bones714
SO.California
Post Number: 65
Anythings possible, just need another satellite setting then hook up your lines to the diseqc.
Username: Mc_sunny
Post Number: 328
nice diagram
Username: Mc_sunny
Post Number: 329
Updated
Bell
Key00 608EE36962EABD1B0B1ACF6CDAAE3A16
Key01 3ABACD0603CE6D97ECFB9E68D45E21C6
Updated
Dish
Key00 24D21E6D11F0951A6F746EBDBCC69254
key01 511C68073AE01ECED949D052E9DBBE0C
