Memphis MOJO 15" or Treo SSX15"
Username: 420alldaylong
Post Number: 263
Memphis MOJO 15" 1000RMS or Treo SSX15" 2500RMS
I'm thinking of trading my SSX15" for a MOJO15" the only reason I'm thinking of doing this is bacause a good 2500RMS amp are expensive and a 1000RMS are not. I should of thought of this before but I was excited to get that SSX15"
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 9159
save.....do it right the first time
Username: Basshead86
Google is your Friend, FL
Post Number: 6116
wow....what a downgrade...not only ar you sacrificing SQ, but build quality as well...shame:-(
Username: Halter
Paulding, Ohio
Post Number: 251
I love my memphis mojo.. they are underrated than can handle more than that....it pounds I Would recommend that...umm make sure its a nice design box though..6.0 cuft box
Post Number: 264
MORE OPINIONS PLEASE
Post Number: 6119
dude, just save your money and buy an amp capable of powering it.
Username: Frkkevin
Lake Worth, Texas US
Post Number: 849
Treo over Memphis any day..
Username: Yamahabanshee1
Paulding, Ohio USA
Post Number: 382
like halter said! its an amazing sub! can get very loud! i love mine. pushed by a 1000D.
Username: Frkkevin
Post Number: 853
6 cubic foot is a bit large for a 15" .. especially if your over powering the sub.. can you say bottoming out? I own a Memphis 15" LVS.. nothing compared to my RE SX 15".. but I've heard both Mojos and Treos and I've gotta stick to Treo.
Username: Krazyj
Post Number: 111
i personally think memphis subs are great but the mojo is on the sloppy side
Post Number: 266
Smitty
1000D what name brand.
Halter
I call memphis audio today just to check out what kind of box the MOJO15" would need they recommended a 3.5cf 2.5"x15.5"16"long
Username: Frkkevin
Post Number: 858
that sounds more like it.. 3.5-4.0 cubic foot is about the normal for a 15".. but I seriously hope your not going to get a Memphis over your SSX
Post Number: 269
It looks like I'm going to keep the SSX15"
like Chauney said save up an do it right the first time. But it is going to take longer to buy a amp but it should sound sweet. THANKS EVERYBODY THAT POSTED YOU TALKED ME INTO KEEPING THE SSX15"
Username: Kenwa
Post Number: 297
I have never heard the SSX but dont question the build quality of memphis b/c they do make good products. They are not SQ oriented whatsoever but they do get VERY loud which is what they are made to do.
Post Number: 6139
Username: Juliob
Santo DomingoDominican Re...
Post Number: 2501
^kenny the ssx is better... joey what amp do you have cuz you might strap 2 and might be cheaper. But yeah save some money
Los Angeles, CA USA
Post Number: 5750
get a mmat dreadnut if you want a 1000wrms sub. i heard one this past week and it sounded awesome. its loud as hell too.
Username: Juliob
Post Number: 2503
^^^^ those are expensive
Username: Halter
Paulding, Ohio
Post Number: 253
A mojo is by far SQ..a mojo is stictly..spl..and yes that what memphis recommends the box but my 6.0 cuft box the mojo eats it up....memphis is real good quality..I love it..
Username: Halter
Paulding, Ohio
Post Number: 254
edit....a mojo is NOT sq
Username: Adddisorder
West palm, Florida
Post Number: 858
strap 2 nine.1s
Paulding, Ohio USA
Post Number: 383
who ever asked its a memphis 1000D amplifier
Username: Jkidder
Spring hill, Florida Usa
Post Number: 236
2 nine.1's r 620 dollars together. cant u get a 2500d for judt under 500?
Username: Crayola0
Wisconsin
Post Number: 1125
what size dreadnaut did u hear...and was it louder than ur sx?
Post Number: 273
Juliob
Right now I have a Rockford T3002 pushing a solo L5 15"
Los Angeles, CA USA
Post Number: 5755
1 heard a 15 dread powered by a kicker 1200.1 in a older model honda civic hatchback. it was about same. from outside his seems louder but inside the car mine seemed louder.
Post Number: 274
Mat ro JK
What is there website?
Username: Juliob
Post Number: 2523
joey.... even a 2000w rms amp can bump that sub nicely... a soundstream pca 2000d can do that or if you want more output for the money get the pca 3500d.
Username: Renegadesrun
Lafayette, IN US
Post Number: 82
Ive run both, i sell, and install both, have for over 5 years.....that said.
Built quality? Equal. Period.
Output? Mojo.
SQ? SSX
Price? Mojo.
Looks? SSX
Mojo will take 2k daily. Without a question.
/post
Username: Johnfiac
Il USA
Post Number: 417
what price range for a amp for the treo? I can probally find you somthing to push 2000-3000K for around 600-800$ but what ohm load?
Lafayette, IN US
Post Number: 89
What VC configuration you choosing?
I can get you a new Planet Audio for under six that should do 2k without a lightening strike. After that, the prices go up steaply. Closest would be the memphis Mojo amp.
Personally? I buy the amp first. Then buy subs to match the load. If a sub doesnt sound as well as id like, or hit as hard as i would like, i build an enclosure to make it do so.
Post Number: 302
I can get a Planet Audio VX2200D for $568.35 from TECHRONICS.COM but doesn't BOSS owe them.
Post Number: 303
SSX15" dual 2ohm
Lafayette, IN US
Post Number: 96
Lost track of who owns who.
It will do the trick for that price. Ill guarantee (and warrantee) you one that not refurbed for that price if you want one bad enough.
Username: Mike_stokes
Post Number: 9
whatever you do, DO NOT get rid of that sub! that would be a SERIOUS downgrade in sq, spl and build quality.
Post Number: 355
I'm going to keep it but I'm saving to buy a good 2000 watt amp. What would you recommend the amp need to be 1 ohm stable.
Post Number: 12
i would recommend my amp! it's the treo we talked about in another thread. oh yeah it is the ssx1500.1 amp, so it was made specifically for that sub
Post Number: 361
Didn't you say there was something was wrong with it on the other thread.
