Gold Member Username: Crayola0Wisconsin Post Number: 1161 Registered: Jun-06 | How much power can an si mag 15" handle cause it says it has 950 watts rms...how much can it actually handle |
Gold Member Username: Basshead86Google is your Friend Post Number: 6416 Registered: Aug-05 | 1200-1500 depending on the box im sure.... prob more or less depending on the box as well. |
Silver Member Username: Th3pwn3rChicago, Illinois U.S.A Post Number: 455 Registered: Jul-06 | I would just give it what it's rated at for daily.Jaymes you don't have that much money for a new sub do you lol?I just don't want you to blow it or any other sub you get. |
Gold Member Username: Crayola0Wisconsin Post Number: 1162 Registered: Jun-06 | cause i was thinkin about gettin teh old hifonics bx1500 or whateva the name is...1500@1 ohm but its overated so would that work alright..or i was thinkin about gettin an ed nine.1 cause of the 1200 watts at 12.2 volts |
Silver Member Username: Th3pwn3rChicago, Illinois U.S.A Post Number: 458 Registered: Jul-06 | Get the ED. |
Gold Member Username: Crayola0Wisconsin Post Number: 1163 Registered: Jun-06 | thats what i was thinkin...i have $160 bucks right now...lol |
Gold Member Username: Basshead86Google is your Friend Post Number: 6422 Registered: Aug-05 | def. just give it a good 1000wRMS you will be fine. |
Gold Member Username: Crayola0Wisconsin Post Number: 1164 Registered: Jun-06 | aight will do..any amps that do a good 1000 watts that are cheaper than the ed nine.1? |
Gold Member Username: Basshead86Google is your Friend Post Number: 6425 Registered: Aug-05 | no. get the ED...and use the 'got coups' code.HAHAHA |
Gold Member Username: Crayola0Wisconsin Post Number: 1165 Registered: Jun-06 | i already have the page bookmarked for the discount amp...lol |
Gold Member Username: Logan__tilleHamilton, Indiana United states Post Number: 1258 Registered: Feb-06 | lol. get the ED. |
