you'll have to look for an already existing hole or tap into a larger the necessary grommet on something else comming through the fire wall. if you can't find either, then you'll need to drill a new hole. make sure you put a grommet on the hole you drill too and make sure you don't drill into anything on either side of the fire wall or possible in between.
