Keep getting error when loading new bin
Username: Mph201
can anyone help me as to why this hapening? I also loaded bins previously for pasat 2500. This is the first time i'm loading a bin to my 2700.
Username: Bones714
Post Number: 34
Have you tried UNZIPPING the files. I just learned how to flash my Sonicview last week and my Pansat 2700 today, all I had to do was unzip the files. What's your problem? More details!
Username: Mph201
I have unzipped the files. When I have tried using both the blacklist updater 1.4 and the loader that came with the bin. When the first LED flashes press download or write bin. It stays at 0%. For the blacklist loader it says "error" or failed.And for the loader that came with the bin, it just stays at 0%. So yeah that's my situation. Any help would be greatly appreciated.
Username: Mc_sunny
Post Number: 300
factory reset before downloading it
Username: Mph201
how do you factory reset?
Username: Abj
Post Number: 325
your cable could be bad too !!!!
Username: Hawaiian_time
Hawaii
Post Number: 600
Yeah, make sure you're not using the same cable as the one you use for the 2500.
Username: Mph201
Post Number: 7
but it's a 9 pin cable, DBS Female ends. The cables fine cuz i just went to my friend's house to test on his clone 2500 by loading an old bin. It worked. But yeah i think this cable's fine for 2700. But yeah, why can't i not use the same cable for 2500 and 2700?
Username: Mph201
Post Number: 8
wait just an error i made there. I tested the cable on a 2700 clone. not 2500. it worked on his.
Hawaii
Post Number: 601
Both cables look the same but the wiring inside of the cable has different connections from pin to pin.
Username: Mph201
Post Number: 9
so wat do you call the wire that I should use for my pansat 2700a? And i used another different wire at my friend's place on his 2700 clone. Can I use that one?
Username: Hardrockstriker
Post Number: 587
You need a null-modem cable. It should say "null-modem" on the cable, otherwise it's a straight-thru.
Username: Mph201
Post Number: 11
thanks man. i'm gonna go buy one right now. O one more thing. When I load the bin, do I have to wait for the first LED to light up and then I can load? or do I just load it as soon as it says "ON"? Thanks again.
Username: Bones714
Post Number: 35
I have the receiver off first, when ready to transfer data. Click download then turn on your STB, data should transfer.
Post Number: 589
With Pansats, I just leave the receiver on then open and run my loader. Viewsat loaders need to have the receiver toggled from "off" to "on".
Username: Dish_inq
Ontario
Post Number: 17
Do you guys have fix for Fortec Classic Na.
Username: Mph201
Post Number: 12
alrite i got it to load the bin :D. But..now i don't have any channels. It just says loading picture. Any tips as to why?
Username: Mph201
Post Number: 13
nevermind got all of em back :D thanks to everyone who helped me. I really appreciate it.
