Bronze Member Username: Bsman
Sarnia,
Ontario
Post Number: 13 Registered: Sep-06
Posted on Im wonderin what to tune an infinity 12 inch SVC 300rms to in like 2 or 3 cubes? |
Silver Member Username: Denali_on_22s
Maryville,
TN
Us
Post Number: 253 Registered: Feb-06
Posted on depends on whether you want low or loud bass... that infinity probably wont get very low so id tune it around 36-38, 40 for the most SPL |
Silver Member Username: Renegadesrun
Lafayette,
IN
US
Post Number: 124 Registered: Oct-04
Posted on FS of the sub? |
Sarnia,
Ontario
Post Number: 14 Registered: Sep-06
Posted on ok so if i want it as low as i can get it i should try like 36? |
Sarnia,
Ontario
Post Number: 15 Registered: Sep-06
Posted on FS? |
Sarnia,
Ontario
Post Number: 16 Registered: Sep-06
Posted on Im reading the manual an it says i can tune it to 33 in 2 cubes |
Lafayette,
IN
US
Post Number: 125 Registered: Oct-04
Posted on One of the "thiele small (t/s) parameters". Roughly put its Resonant frequency... the frequency the subwoofer most easily resonates at and also a number which i would recommend not tuning below. Which apparently is common in here as incorrect amp adjustment judging by the amount of subs that "knock" when putting the power to them. |
Lafayette,
IN
US
Post Number: 126 Registered: Oct-04
Posted on When in doubt......follow the manual. |
Sarnia,
Ontario
Post Number: 17 Registered: Sep-06
Posted on well, it says i cant tune it below 28 but it recommend tuning it in 2 cubes to 30 more like 33 i would think at least |
Sarnia,
Ontario
Post Number: 18 Registered: Sep-06
Posted on is that what i should do?? |
Lafayette,
IN
US
Post Number: 128 Registered: Oct-04
Posted on 32-35 IMO, are great for all around streat beating. In essence....I agree with the manual. |
Sarnia,
Ontario
Post Number: 19 Registered: Sep-06
Posted on ok then thats what i will do thanks a lot for the help |
Bronze Member Username: Bayrent88
Ingleside,
Texas
Post Number: 41 Registered: Jul-06
Posted on what is a good site to use for the calculate box ports |
Silver Member Username: Adddisorder
West palm,
Florida
Post Number: 953 Registered: Jan-06
Posted on subwoofertools.com |
