Loader trouble
Username: Dougefresh
Chatlottetown, PE Canada
I'm new to this i've saw it done before, but basically i need to program my viewsat platinum using the "loader 2" i understand, i've downloaded it but when i click "open files" to load the correct files before going PC--->STB the required files arent there? any help?
Username: Morispastora
Thunder bay, Ontario Canada
Post Number: 408
Here are some basics.
I suppose that you had Winzip or other program.
The most important thing is: Save your file in a folder you name and don't forget where it is.
To do that you have to unzip the file first
Username: Johnner
Miami, Florida
Post Number: 612
Turn the receiver off and press PC -> STB then turn the receiver ON!
Username: Hardrockstriker
Post Number: 568
yes, what Johnner said should work. It's a little quirk with loader2 program.
Username: Ronmcc02
Post Number: 10
I have loader trouble also. when trying to transfer the bin I get a reading that says sending zrqirit and resending zrqirit and then a frame number comes up quickly and then resending again. But doesn't load. I have a viewsat 2000. Any help here?
Post Number: 574
Are you doing what Johnner suggested?
Username: Abj
Post Number: 313
Anyone having trouble loading bins for viewsat.
go and check out this viewsat instructional video
http://forums.dssteste r.com/vbb/showthread.php?t=49576
note: make sure dsstester is togather
Username: Djsmith
Post Number: 376
application/pdfUpload
http://fta.badongo.com/<<< its my personal site but you can download anythiing that you would it :-).
Username: Djsmith
Post Number: 388
bump
