Captive works bin
Username: Frobisher
Cambridge, Ontario Canada
New bin for cw1000 is out on dss. Can some one please tell me if it will also work with Captive works 600s premium? Thanks
Username: Abj
Post Number: 316
nope....
Word is within a week 600s should be up...... we'll see
Username: Djsmith
Post Number: 368
the long awaited cardless fixes for the 600s and premium will be released later in the week after futher testing. the cardless fix is out for the 1000 and all channels are working on both providers.
I found this at dsscommuity.. sorry sounds like you still have to wait abit Neil Sheel
Username: Frobisher
Thanks DJ.
Username: Lklives
Post Number: 4484
but there is this...
Here is a little something that has been cooked up. It is offshore, very well hidden, and most important it will get your tv back up on the CW600S/P and
Skyview 500
This is private and independant but free for anyone who wants to use it.
Just use the current CW/SkyView software, hook your null cable to your box, be connected to the internet and just watch tv.
This is only for dishnet
DO NOT HAVE THE CURRENT KEY ON YOUR BOX (it will not work if you do)
Select your com port
Pess F1 key then 555 to activate the patch.
Sorry nothing for the cw500
client_new_USV0.1 RC6.zip
[link removed]
Username: Spike52
Post Number: 7
Thanks LK
Username: Zunna
Post Number: 106
is there any hope for pansat bin coming out soon?
Username: Lklives
Post Number: 4486
Zunna...what does Pansat have to do with this thread SUBJECT (Captive works bin)....NOTHING!...what U did is referred to as "HIJACKING" aka "stealing" a thread..Go post in a Pansat Subject thread!...common courtesy!
