Viewsat Warning About The new Fixes!!!!
Username: Ong_tu
Post Number: 183
Be carefull with those.. Just a warning...
Posted by TDG at other forum(s) :
"Viewsat bin stability warning
Seems they may have jumped the gun a bit on these bins. I've been told to warn people of the possibility of no LED after flashing.Viewsat will release new bins shortly and any who have the lights out syndrome are instructed to send them back to Viewsat for a free replacement. This hasn't occured alot, but Mr V wanted me to make this announcement to let you all know that IF it does happed to you, your unit will be replaced, free of charge. Contact viewsatusa.com to replace any defective units. Keep in mind this is only happening to a very small % of the units.. Keep an eye out for new releases a little later. Thanks."
This may apply to clones I have had mine up for 12hr. Ong Tu
Username: Timscarlet
Usa
Post Number: 230
what about installing the factory bin first, then the new bin, has'nt this help the errors people been having, the 1061 factory file works on mine.
Username: Ong_tu
Post Number: 184
I have had no problem installing new bin right over the old, and from what I'v read no one else has. If you got a clone be carefull!
Username: Ouchi_collashi
Post Number: 53
The clones are safe as the problem is clone kill code in the bins for the authentic viewsats. If you have a clone you have nothing to worry about.
Username: Lklives
Post Number: 4430
Question...how can MR V tell anybody to return their Viewsats to Viewsat if there is a problem with the new bins using "3rd party" software!.....and Viewsatusa.com or doesn't allow "illegal software other than "factory" bins!...and ANY bin for Dishnet or Bev is considered "illegal" and 3rd party"....sounds BOGUS to me and contradicts the "Viewsat" policy 100%!...I say TDG or anyone who made that statement on behalf of Viewsat is 100% BS!
Usa
Post Number: 231
yes LK, why would anyone even talk about sending receivers back using bin files to hack tv. very bogus, very stupid thread if i say so.
Username: Ong_tu
Post Number: 186
LK, those were my thoughts also, but thought it prudent to post this! Better to let people know and make up there own mind, and to get inputs such as yours. My thought was that if they sent it back in that they would reset to factory defaults.I will do some more research on this.
Username: Hawaiian_time
Hawaii
Post Number: 593
I agree with LK. This post would suggest that VS condones the use of illegal software in their receivers.
Username: Johnner
Miami, Florida
Post Number: 611
Viewsat Platium
http://www.dss central.net/files/uploads/DBPSW_060923AS_PLATINUM.zip
Working just fine!
Username: Ronmcc02
Post Number: 9
Has anyone had the problem of the loader2 not loading? This is happening when trying to load bin. It reads "sending zrqirit" and then few seconds later it reads "resending zrqitit". Then a frame number blinks up behind it. I don't know what the problem is. Any thoughts on this one? Please help.
Username: Thedssguy
Nowhere boring, Fl. US
The first post was in haste when realized people were having problems. the .pgm is safe, but some people weren't letting it finish flashing. This was also posted in that same thread a little later:
"Some probs are from users not waiting long enuff after flashing. The unit now has an extra step involved. When finished it will say END, then 0000, then boot, then END, then back to last channel or 0000. You must wait till this process finishes before unplugging. Unplugging while it is finishing causes the no LED failure. Also, do NOT clones this bin receiver to receiver via serial ports. I've had no probas at all myself, so this is an FYI. If unit is dead and you have another VS, load a factory bin on other VS, and attach null cable to dead unit. Make sure first units is on and working, then turn dead one on via rear switch and try to clone from working unit. This will work in many cases, but if not, VS will replace unit free of charge."
If you have a dead unit, you can get the address to send back at viewsatusa.com. Send unit with note "Dead unit, no power" it will be replaced or repaired free of charge.
Also, for the record, You guys know i don't usually come here, but this was a quote from my post. I just wanted to clear this up. LK has a plate full so cut him some slack... Almost all FTA units will be back up this week. Viewsat didn't put the fake code in allowing others to disect the .pgm. Now opensource is up (giving full credit to Viewsat) and we will see someone porting the solution from linux to windows, and FTA units will magically start coming back up. Today it takes more than opensource to get the job done. It takes engineers, labs, & $$$. But in the end we all have tv again.. :-)
Username: Dave_singh
Post Number: 35
HAVE A PROBLEM MY VIEWSAT WORKS FINE YESTERDAY
WHEN I TURNIT ON THIS MORNING, 110,119 SIGNAL GONE. PLEASE ADVISE IF THIS IS NORMAL
Post Number: 36
WHEN I TURN IT ON THIS MORNING, 110,119 SIGNAL GONE. PLEASE ADVISE IF THIS IS NORMAL
Username: Lklives
Post Number: 4493
U better learn how to use the internet and any forums first...lose the CAPS, considered rude and yelling!...then learn how to READ and U might learn something..plenty of manuals and guides to use to troubleshoot any problems U have..
Yes its NORMAL to lose all channels every morning...just like losing your car every day!....LMAO
Post Number: 40
will this fix soon , or i need to move my dish
Username: Lklives
Post Number: 4496
Viewsats have had the new WORKING fix for 3 days now...and it works fine..OF course its NOT normal to lose channels daily with a working fix!..U have other problems...HARDWARE problems or don't know how to use your receiver!
Username: Tin
EARTH
Post Number: 85
I had entered the new bin to my viewsat and the end its said fail can someone tell me the reason thank you...
Username: Kll
Post Number: 68
dave singh is your viewst back on?
Username: Lklives
Post Number: 4501
SB ...U need to read at a REPUTABLE DSS sie that has files , manuals , and how to Guides!!...U have either bad or wrong flash cable or serial port
Username: Rick57
Hey Ronnie If your Downloader keeps saying resending,that means the bin you double clickled and loaded is still zipped and needs extracted to able to use it as a bin when u select it through open files option in loader 2 program.
