Username: Extremesound1 Coventry,
RI
United states
Post Number: 235 Registered: Mar-06
Sunday, September 24, 2006 - 22:26 GMT the box is done all i need to do is wire it up problem i used the diagram from crutchfiled my sub is a 2 OHM dvc.i want to hook it up to a 1 ohm...here it what ive done in blue and black know do i take coil negative to amp and coil 2 positive,,,,or coil 1 positive to the amp and coil 2 negativge
RI
United states
Post Number: 237 Registered: Mar-06
Sunday, September 24, 2006 - 22:43 GMT or do i just take coil 1 negative and positive to the amp quickly i want to hear this thing tonight
Username: Th3pwn3r Chicago,
Illinois
U.S.A
Post Number: 303 Registered: Jul-06
Sunday, September 24, 2006 - 22:45 GMT I wish I could help but that drawing is soooo bad lol. I can't understand it at all.Just hook it up according to that rockford diagram.
RI
United states
Post Number: 238 Registered: Mar-06
Sunday, September 24, 2006 - 22:50 GMT but which is coil 1 and coil 2,,know what i mean.my kicker sub has a coil 1 positve and negative,so does coil 2..
Username: 420alldaylong Post Number: 291 Registered: Sep-06
Sunday, September 24, 2006 - 22:53 GMT Positive to Posstive run off Negative to Negative run off
Illinois
U.S.A
Post Number: 305 Registered: Jul-06
Sunday, September 24, 2006 - 22:56 GMT Just wire all your positives together and all your negatives together and you'll be fine.Send a wire to from your amp's positive to each positive on the coils and send a negative from your amp to each negative on the coils.
Username: Oglejust Post Number: 144 Registered: Aug-06
Sunday, September 24, 2006 - 23:02 GMT its all neg. to neg on amp and all pos. to pos on the amp.
Username: 420alldaylong Post Number: 293 Registered: Sep-06
Sunday, September 24, 2006 - 23:08 GMT The diagram explains it self.
Username: Makmillion MN
United States
Post Number: 626 Registered: Apr-06
Monday, September 25, 2006 - 21:46 GMT Kicker subs have dots on one set of terminals.. the others have no dots.. that's how they seperate their coils visually
Username: Blainew Post Number: 1610 Registered: Nov-05
Monday, September 25, 2006 - 22:45 GMT u want the neg of one coil to the neg of the amp and the positive of the OTHER coild to the positive of the amp
