1 inch MDF
Username: 420alldaylong
Post Number: 366
1 inch MDF
Where do you get it at I've tried Home Depo and Lowe's they only have 3/4
Username: Frkkevin
Lake Worth, Texas US
Post Number: 967
the home depot about 45 minutes away from my house carries 1-1/4 MDF.. tempted to use that on my next box
Username: Rovin
Trinidad & T...
Post Number: 9198
thats gonna be a stiff but heavy azz box -lol .......
Los Angeles, CA USA
Post Number: 5940
lol rovin. imagine with slot ports and all the braces.
Username: Kenwa
Post Number: 312
I have heard of people just double stacking half inch and glueing it but im not sure how that works out.
Username: Phil_salisbury
Post Number: 96
LOL, do you guys know how much 1" MDF actually weigh's? Hint - 12" x 12" x 1" MDF = 4lbs or .44 oz per sq.in.
So, that would mean a 12" x 12" x 1 1/4" MDF = 5lbs. or .55 oz. per sq.in.
Either way, your talkin one heavy azz sub box.
Username: Drivingreckless
Near tampa, Florida United state...
Post Number: 1842
at least it wont flex:-)
well u will need braces
hey phil i saw ur boxes in the gallery of ur buisness page
i saw the way u brace ur box...unique but
wont it cause turbulance in the box???
just wondering not trying to put down ur boxes im lookin into building another one and wondering bout how bracing works
Post Number: 98
Drivin,
To my knowledge, the bracing does not causes any issue's in forms of turbulance, port noise or anything else.
If it did, I'm sure more than a few customers would have already expressed there displeasure about there use.
Bass asked me the same question in another thread of the type of bracing I use and I gave him the same answer with an explanation as such.
Post Number: 1843
ookay :-)
Username: Th3pwn3r
Chicago, Illinois U.S.A
Post Number: 442
My box is 2 inches thick : / and it's pretty much impossible for any "average joe" to move.So if you're not strong as hell you aren't moving it lol.It took two guys just to lift the box into my van.I don't know where I'm going with this but my box doesn't flex I guess?It would be pretty hard to steal too.
Post Number: 99
2" thick!!!! jesus.
I've built enclosure's for customers in the past that want the entire enclosure 1" MDF and even that is to the extreme, but 2", why not just make plywood forms and pour in some 5000 psi ready mix concrete to make an enclosure.
I would be heavy as he!! and it wouldn't flex and weight just about as much.
Username: Th3pwn3r
Post Number: 445
Hahaha!Crazy as hell.It's also fully resined inside too lol so that adds a bit more weight.
Los Angeles, CA USA
Post Number: 5963
all i got to say to you robert is "DAMN".
