New member Username: Livin_loud_16Mauston , WI United States Post Number: 1 Registered: Sep-06 | i want to get a new set of subs and i either want to get two 12" T9500s or two 12" L7s.i need your advise on what pair to get. |
Gold Member Username: Extrmndor3Chicago, Ill Us Post Number: 1957 Registered: Feb-06 | hah both of them suxs 9500 suposed to beat the 10 inch jl audio w7 buts its not true kicker l7?? hah athe most retunred woofer on the market |
Gold Member Username: Logan__tilleHamilton, Indiana United states Post Number: 1215 Registered: Feb-06 | what do you want Sound quality,or just loudness, ot a mix of both? whats your budget? |
Silver Member Username: Sb2012Iowa US Post Number: 296 Registered: Jul-06 | agreed. why those two? whats ur budget dustin? and how much power you have? so we can get you on the way to bigger and better things |
New member Username: Livin_loud_16Mauston , WI United States Post Number: 2 Registered: Sep-06 | well i need both subs and amp if i did get the T9500 i was going to get two 81000D amps. and my budget for subs doesnt matter i want something thats going to have good spl but yet have descent sq as long as they arnt an outrageous price. Just list some company's that you think im looking for and give a price range of how much there going to cost and list what amp or amps that would be best for them. |
New member Username: Livin_loud_16Mauston , WI United States Post Number: 3 Registered: Sep-06 | well thanks for the advice you guys! I guess im going to get the T9500 sence no one wants to help me out. |
Gold Member Username: Logan__tilleHamilton, Indiana United states Post Number: 1291 Registered: Feb-06 | whats your bidget? |
Silver Member Username: AdddisorderWest palm, Florida Post Number: 951 Registered: Jan-06 | [quote]well thanks for the advice you guys! I guess im going to get the T9500 sence no one wants to help me out.[/quote] ok fine |
Silver Member Username: 420alldaylongPost Number: 382 Registered: Sep-06 | He ask a question which of the to should I get Kicker or MTX and noboby help. Dustin There both good get the ones that are the cheapiest in price. |
Silver Member Username: 420alldaylongPost Number: 383 Registered: Sep-06 | lilrob That MTX 9500 10" does out perform the JL W7 10" |
Gold Member Username: Extrmndor3Chicago, Ill Us Post Number: 1971 Registered: Feb-06 | nope u wrong the 10 inch 9500 outperfomr the jl audio w7 10 inch but check this out man the mtx all of the version are the same in the motor they just put a bigger basket and a bigger cone to make it a 12 or 15 inch BUT wat about jl w7?? the 10 have a 23mm of one way xmax ok this is all the 9500 the woofer to beat but wat about the 12 and 13??? the 12 has 29 mm 6 more millimeter than the 10 plus a bigger cone addin more spl and NOW beatin the mtx but wait wat about the 13??? the 13w7 have 1 inch more cone plus 32 mm of xmax and the 32 mm its 10 mmm more than the 10 inch and thinkin about this the only jl w7 the 9500 can beat its only the 10 inch jl w7 but wait compare the 12 and 13w7 with the 9500 it will beat the cr@p out of those 9500 fakers, but hey wat about the sq the 9500 sound horrible and its not wort it, the jl audio super clean and one hting its one of the few subwoofers that its quite whileexcurting so the conclution its that the mtx its louder than the w7 only in the 10 inch model, 12 13 inch w7 will smoke those fakers plz dont let your frineds buy mtx :sm29: |
