Terminals on speaker
Username: 1lakerfan
Post Number: 38
I have the RTi10 front speakers and they have four terminals on the back. Someone me that one set is for pitch and one set is for bass. Which set is for the bass (two terminals on the top or the terminals on the bottom).
Username: Project6
Post Number: 11088
Read up
https://www.ecoustics.com/electronics/products/articles/109419.html
Username: 1lakerfan
Post Number: 39
I'm not bi-wiring or bi-amping I'm just connecting the speaker to the recivers. Does it matter where I connect the speaker wire on the speakers.
Username: 1lakerfan
Post Number: 40
reciever
Username: Project6
Post Number: 11089
As long as they are all connected to the source.
Username: John_s
Columbus, Ohio US
Post Number: 1104
Albert,
As long as the removable connector bars that link the two sets of terminals are still in place, you can connect your speaker wire to either top or bottom sets, it doesn't matter.
Username: Praetorian
Post Number: 438
Although I recommend replacing the bridge with the wire you are using, i.e. run it the same wire through both sets of terminals instead of a bridge.
