FTA?????????
Username: Djh88310
Anyone know what happened to future-fta web site? Thank you
Username: Oleg1474
New port richey, Fl Usa
Post Number: 349
MY FRIENDS ,I MIGHT RELEASE NEW BIN FRIDAY
Thank you OLEG/PHD
Username: Ong_tu
Post Number: 167
I have and it is(down)
Username: Ong_tu
Post Number: 168
Oleg, I know where you live keep up this bullshit and I will pay you a visit. If you need attention go play in the middle of a freeway---
Username: Zunna
Post Number: 102
any fix for pansat??
Username: Snowgoose621
Charlottetown, Pei Canada
i have one,you want it??
Username: Rotormanrx4
Post Number: 97
JOHN FUTURE-FTA IS BEEN MOVE TO ANOTHER WEB ADDRESS. I HAVE IT ON MY HOME COMPUTER IF YOU GIVE ME A CHANCE I WILL POT IT HERE IN THE AFTHERNOON.
Post Number: 98
ZUNNA SO FAR LAST TIME I CHECK THERE`S NO FIX YET.THEY SAY THE SAME THING THAT THEY ARE WORKING AND BE PATIENT
Username: Donnie1973
Tennessee
Post Number: 402
future-fta.info
Same address.
Username: Zunna
Post Number: 105
k thx JR juss keep giving the latest info :-)
Username: Krishn
Question: There was an earlier post at this URL:
https://www.ecoustics.com/electronics/forum/home-video/271643.html
Which had
<begin>
nFusion v1.0: UP Fully Open Beverly and Charlie. Not effected by MAP3B.
nFusion v2.0: TBA
<end>
I could not find this FTA receiver anywhere in google search. Anyone has any idea?
Can a reciever be unaffected by MAP or in other words can habdle any MAP calls?
That thread has only one post a few days back that's why I posted here.
Can someone knowledgeble shed some light on this?
Post Number: 99
John this is the old web address for future-fta that doesn`t open http://www.totalfta.com/index.php?s=b7b3fa70e52273a49b784b981720e7b2 .Hi dantetn as you can see it change try it.thanks
Post Number: 100
Sorry you don`t need to copy just click on them if you want to try both no problem you will see one won`t open and second will.thanks
