Username: Dub_c Post Number: 171 Registered: Mar-06
Tuesday, September 19, 2006 - 02:27 GMT Which is the best and cheapest mono amp that puts out 1200WRMS?
Username: Ctmike Ct.
Post Number: 1799 Registered: Feb-06
Tuesday, September 19, 2006 - 02:29 GMT how cheap you looking for? you can get a nine.1 for $315 or a kicker kx1200.1 for about $360. both new with full warranties.
Post Number: 1800 Registered: Feb-06
Tuesday, September 19, 2006 - 02:34 GMT bump ^ dammit.
Username: Theelfkeeper Stockbridge,
GA
Post Number: 2982 Registered: Feb-05
Tuesday, September 19, 2006 - 03:17 GMT 1200W RMS at what load?? because that kicker puts out 1200 at 2 ohms where the eD puts out 1200 at 1 ohm... Orion is another choice you could look into. also Directed/Viper makes some cheap amps.
Username: Juliob Santo DomingoDominican Re...
Post Number: 2411 Registered: Dec-05
Tuesday, September 19, 2006 - 03:19 GMT DUB C you need to say a budget. I'd say lanzar vibe 1200d would be the cheapest one, then hifonics 1206d, soundstream pic 1400.1D, PA a1800db, Soundstream PCA 1000d and raising up that way. But if your budget is 300$ then you can afford better amps. 200$ is the minimum for an amp putting 1200w rms and conserve good quality/durability for the money
Post Number: 1808 Registered: Feb-06
Tuesday, September 19, 2006 - 03:24 GMT weird, i thought for sure i saw he said 1ohm. but brandon, the kicker kx does 1200wrms at 1ohm, it's lst years model.
Username: Dub_c Post Number: 172 Registered: Mar-06
Tuesday, September 19, 2006 - 03:30 GMT See I dont know my budget, I can tell you I do want to spend some $$$, but not like $500 or anything, oh yea, 1200WRMS @ 2 ohms. Thanks
Post Number: 2413 Registered: Dec-05
Tuesday, September 19, 2006 - 03:59 GMT jbl Gto 1201, infinity 1211A (CEA compliant but nobody likes it cuz is kinda messy), kicker ZX 1000, rockford X6. BTW directed audio has the d2400 for only 209 shipped (good amp for 1200w rms 1 ohm stable.) I forgot to put it ^^^^ there
Username: Night_mirage AmmanJordan
Post Number: 462 Registered: Jan-06
Tuesday, September 19, 2006 - 11:18 GMT wooow Brandon . kx1200.1 is 1ohm load , Not 2 I would say JBL its about 290$ and 2ohm load . if u want cheaper it would be budget amp , I don't prefer that .
Username: Dht Guadalajara,
Jalisco
Mexico
Post Number: 48 Registered: Sep-06
Tuesday, September 19, 2006 - 17:42 GMT Audiobahn Dual Jensen Boss Volfenhag American HiFi Rockwood Legacy Kole Pyramid MA Audio Kingwood Newer Sony Pyle XPlore Lanzar(Except Opti Drive amps. Those are pretty good actually) Audiofonics Rampage Audiovox New Soundstream Phoenix Digital Formula Koiker Nitro Power Acoustik Lightning Audio Niche Verge Crunch check models on this brands (im not saying there good, justo cheap)
Post Number: 2418 Registered: Dec-05
Tuesday, September 19, 2006 - 17:44 GMT your best bet would be the jbl GTO, cuz is cheap and reliable
Post Number: 1820 Registered: Feb-06
Tuesday, September 19, 2006 - 17:46 GMT wow, looks like you copied listings of car audio that wal-mart or kmart would carry! all junk. i would not recommend any of those brands.
Username: Adddisorder West palm,
Florida
Post Number: 836 Registered: Jan-06
Tuesday, September 19, 2006 - 20:38 GMT looks like the sh!tty list off the good bad list
Username: Cavsmaxima New York
United States
Post Number: 253 Registered: Aug-06
Tuesday, September 19, 2006 - 23:16 GMT kicker KX 1200 wont do it for u. Nice list, Dual Jensen, etc. LOL
Username: Dub_c Post Number: 174 Registered: Mar-06
Thursday, September 21, 2006 - 02:25 GMT Yea I wanna buy something NAME brand, something that lasts, really puts out 1200WRMS @ 2 ohms. I am leaning towards that Kicker.
Post Number: 2451 Registered: Dec-05
Thursday, September 21, 2006 - 02:28 GMT DUB C i think you're leaning for the zx 1000.1 cuz the KX1200.1 is not going to do the work.
Username: Halter Paulding, Ohio
Post Number: 250 Registered: Oct-05
Thursday, September 21, 2006 - 02:53 GMT hifonics 1606D
Post Number: 2460 Registered: Dec-05
Thursday, September 21, 2006 - 17:49 GMT ^^^that's not going to work either... JBL gto or ZX1000.1
Username: Dustin3 Tigard,
OR
U.S.
Post Number: 3511 Registered: Oct-05
Thursday, September 21, 2006 - 17:57 GMT hmm, i wonder y brandon think that the kx1200.1 does 1200 @ 2 ohms.. its not the zx1000
