Memphis and FI-Q
Username: Ckelley
Post Number: 33
I just got a Memphis PRD 1000.1 amp from ebay. Its 1000watts at 1ohm and i was thinking of getting a FI audio Q 1 ohm sub for it. Would this be an alright setup and would i need any electrical upgrade with a 110 amp alternator?
Username: Basshead86
Google is your Friend, FL
Post Number: 6140
hmmmmmm.....
although your alt. is bigger than other smaller cars....it is still underpowered a bit.
you could get away with it if oyu put a yellow-top in the trunk.
and that would be an awesome setup!:-)
Username: Juliob
Santo DomingoDominican Re...
Post Number: 2500
Username: Ckelley
Post Number: 34
What about running that amp at 2 ohms (600 watts) and getting 2 of the X-series.
Post Number: 6147
much better:-)
Username: Ckelley
Post Number: 35
Sealed or Ported?
Muddy have u heard the FI-X series?
