Amp question
Username: Kissdaredevil
Post Number: 19
i have a 92 grand prix. i have a directed d2400 amp. if i run it at 2 ohm will my car be able to handle it fine. it has a stock alternator not a ho alt.
Username: Ctmike
Ct.
Post Number: 1779
whats the rms of the amp, and how big is your alt.?
Username: Makmillion
MN United States
Post Number: 502
If I'm not mistaken that amp will only put out 800wrms @ 2 ohms... if that's the case you'll be fine.
Username: James1115
Ct
Post Number: 6588
What if his alt is 80 amps Mick, will he still be fine? the answer is NO! Untill you know exactly what the scenario is dont be so quick to answer.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 2391
a civic alt is 60A and can't hold 800w rms for example...
Post Number: 20
would a capacitor help at all. i think my alt is putting out between 90-100 amps.
