Bronze Member Username: MoorezySt. Catharines, Ontario Canada Post Number: 59 Registered: Jun-06 | hi i just got new system (made a post not too long ago) and i need to know what wiring to hook up the subs to the amp.. i have a 4 guage amp kit for the amp wiring but i wasnt sure what gauge to hook up the subs to amp with i think i heard 16 guage somewhere but im not sure they are 2 12" kicker cvrs |
Silver Member Username: DrsmithMontana USA Post Number: 681 Registered: Nov-04 | 16 should work fine |
Silver Member Username: DrsmithMontana USA Post Number: 685 Registered: Nov-04 | didnt bump d@mnit |
Gold Member Username: StnorrisIA US Post Number: 1383 Registered: Apr-06 | 16 g will work fine, but i would do 14. i used to run 12 on my 2 12 cvrs. if you only have 16, go to walmart and get that cheap pack of 12 gauge wiring. the strand count prolly isnt that bad, and wire is wire. |
