Username: Alpineduder So u can jack up my sy...,
Hell no
C-a-n-a-d-a
Post Number: 71 Registered: Dec-05
Monday, September 18, 2006 - 01:27 GMT So when i play my sub i can here the bass and the singing. I have a p2 12" on a P3001 amp, what is casueing this, is it normal and how can i fix it to just play bass. My 12" type-r didnt do this i dont think
Hell no
C-a-n-a-d-a
Post Number: 79 Registered: Dec-05
Monday, September 18, 2006 - 01:52 GMT bump
Username: Freezeman_7 Post Number: 206 Registered: May-06
Monday, September 18, 2006 - 01:56 GMT my re does it a lil bit. but not a whole lot. i have to put my ear to it. so its not that big of a deal to me
Username: Drivingreckless Near tampa,
Florida
United state...
Post Number: 1737 Registered: Apr-06
Monday, September 18, 2006 - 01:58 GMT it is a big deal...high frequencies can hurt the sub....turn ur xover frequency on ur amp lower and it should go away
Username: Thomas_g NM
Post Number: 1829 Registered: Oct-05
Monday, September 18, 2006 - 06:04 GMT Ja and make sure u got it on lpf of course....
Username: Theelfkeeper Stockbridge,
GA
Post Number: 2966 Registered: Feb-05
Monday, September 18, 2006 - 08:55 GMT set your LPF to 80Hz. either just use the crossovers on the HU or match the HU and amp crossovers.
Username: Troy81 Tavernier,
Fl
Us
Post Number: 1125 Registered: Mar-06
Monday, September 18, 2006 - 16:01 GMT HPF set to 110, LPF set to like 30 or whatever the sub says,
Username: Bestmankind Los Angeles,
CA
Post Number: 5596 Registered: Oct-05
Monday, September 18, 2006 - 16:04 GMT if you set the lpf to 30 then you will be missing all the good bass frequencies.
Username: Kaos13 Phoenix,
AZ
Post Number: 166 Registered: Oct-04
Monday, September 18, 2006 - 16:08 GMT lol same thing i was thinkin^^^^^
CA
Post Number: 5598 Registered: Oct-05
Monday, September 18, 2006 - 16:10 GMT maybe he is talking about the ssf.
Fl
Us
Post Number: 1126 Registered: Mar-06
Wednesday, September 20, 2006 - 03:20 GMT ssf* sorry, my bad, my amp has an auto lpf so im used to only setting the ssf, thanks chad
