Bronze Member Username: Alfyer5Post Number: 16 Registered: Sep-06 | what do i need to upgrade im running 3500rms at 1ohm load and obviously i need to upgrade my elc but i dont know what to upgrade also some ppl said i need extra batteries in the trunk why?? >_< im a newbie to car audio |
Silver Member Username: BernymacRialto, CA United States Post Number: 256 Registered: Sep-04 | 1 HO alternator, probaly 1 220 HO alt with HO amps at Idle. 1 Odyssey batt or two yellowtops and the big 3, also 0guage wires. |
Bronze Member Username: Alfyer5Post Number: 18 Registered: Sep-06 | thanks ne website where i can purchase? |
Silver Member Username: BernymacRialto, CA United States Post Number: 259 Registered: Sep-04 | Iraggi on ebay, just type in iraggi in the search bar in ebay. As for the odyssey batts, http://www.odysseybatteries.com/, as for the big three look in the thread below this one, it was your thread also. I posted a link in there for the big 3. |
Bronze Member Username: Alfyer5Post Number: 19 Registered: Sep-06 | ok thanks everyone ill tell u when i hook it up or problems ocure |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 11629 Registered: Dec-03 | high output alternator 1/0AWG big 3 battery isolator dedicated deep cycle battery 1/0AWG distribution 3Fd capacitance for filtering appropriate distro/fuse blocks and connectors |
Bronze Member Username: Alfyer5Post Number: 20 Registered: Sep-06 | battery isolater is what? |
Platinum Member Username: GlasswolfWisteria, Lane USA Post Number: 11631 Registered: Dec-03 | google it or refer to www.bcae1.com it isolates the second battery for the audio system so if you completely drain that battery, you can still start your car using the starter battery, while still allowing the alternator to recharge both batteries while the engine is running above idle |
