Silver Member Username: Logan__tilleHamilton, Indiana United states Post Number: 957 Registered: Feb-06 | is this 1ohm stable? http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=235 |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 2356 Registered: Dec-05 | No... maybe the amp can run with lower loads, but the CEA power is at 2-4 ohms.. so i'd run it that way. |
Silver Member Username: Logan__tilleHamilton, Indiana United states Post Number: 959 Registered: Feb-06 | can you run kicker amps at 1ohm |
Silver Member Username: Logan__tilleHamilton, Indiana United states Post Number: 960 Registered: Feb-06 | bump |
Silver Member Username: Van_manBoston South, MA Post Number: 937 Registered: Mar-06 | the SX1250.1 is 1 ohm stable |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 2378 Registered: Dec-05 | you can run some kicker at 1 ohm or 0.5 ohm... |
