Silver Member Username: Adam_sWisconsin USA Post Number: 252 Registered: Aug-04 | OK well I was just looking around for a new amp and I saw the treo SSXD750.1 and I am wondering if anyone has any input about this amp and also if someone knows how much it sells for. I emailed treo but wont get a response from them untill monday at the earliest |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 2369 Registered: Dec-05 | treo amps are great... what subs r you going to push?? http://ampguts.realmofexcursion.com/Treo_SSXD750.1/inside1.jpg check those Fets... for "750w" hehe those guys R crazy. |
Silver Member Username: Adam_sWisconsin USA Post Number: 254 Registered: Aug-04 | I have a 15 Rl-p dual 4 ohm...I havent decided what amp I am going to get yet...just looking at the options...lol...ive also been looking at the kicker zx750.1....so idk.. Do you know how much the treo costs?? |
Silver Member Username: Adam_sWisconsin USA Post Number: 256 Registered: Aug-04 | it didnt bump |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 5976 Registered: Aug-05 | the 750.1 does 1500wRMS at 1 ohm....that isn't on their website i almost got one instead of my DLS A6 but they were out of circuit boards.... |
Silver Member Username: Adam_sWisconsin USA Post Number: 257 Registered: Aug-04 | does anyone have a price for this amp?? |
Silver Member Username: Adam_sWisconsin USA Post Number: 258 Registered: Aug-04 | bump? |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 2373 Registered: Dec-05 | don't know.. the treo is a great amp but if you're just going to push a SS i'd get the kicker zx 750.1... maybe if you were getting 2.. the treo would be a better option |
