Low Signal Strength
Username: 1tina_chick
Post Number: 39
Co*Lsat 4 P 127 flash , low signal anyone know whats up ?
Yes I did check switch , move dish check lnbs x2 etc........ ?
Username: Lklives
Post Number: 4358
could be a million things...start checking hardware...cables, connections, etc..
Post Number: 42
Thanks LK YOU ROCK ! I'm using your poormans dish design
with the home depot hoseclamp and x-tra LNB. I've found from
old flashes it boosts signal strength. ( The Flash Boosts the signal)
many chans. are 66% and breaking up , the only thing I've
changed is the flash. Sometimes
the green signal meter bounces from about 70 to 86 % back and
forth. Yes I did check switch , move dish check lnbs x2 .cables, connections etc.......
Thanks to ALL !
