New member Username: Audiobahn8908Post Number: 2 Registered: Sep-06 | ok , if i turn it up to loud the thermal protection will click on and turn it off.. therefore i have to turn the cd player off then back on.. can anyone help me remove the thermal protection or tell me how to make it stop clicking off |
Gold Member Username: IlluminatorUSA Post Number: 4731 Registered: Apr-05 | https://www.ecoustics.com/electronics/forum/car-audio/258596.html Hope that helps! |
Gold Member Username: TjmutlowPost Number: 2748 Registered: Sep-05 | if you have that amp bridged, i bet it is wired to to low of ohm load, it is only stable at 4ohms, so if you have dual 4 ohm subs, you need to wire series/parralal. see www.the12volt.com under woofer wiring.. |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 2138 Registered: Dec-05 | throw it away |
Silver Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 457 Registered: Jan-06 | Must say i AGREE with juliob....Sony is crap |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 2144 Registered: Dec-05 | hm... earning some respect... lol |
Silver Member Username: MakmillionMN United States Post Number: 417 Registered: Apr-06 | nonsense! they make excellent paper-weights |
Silver Member Username: CavsmaximaNew York United States Post Number: 199 Registered: Aug-06 | i must say i amp pretty pleased with my sony amp never had any problems with it, but then again i only had it for 5 months. But im still getting rid of it lol for the Kx12001.1 |
