Silver Member Username: Hawaiian_timeHawaii Post Number: 509 Registered: Apr-06 | Here's a post from Future(SD1) about 30 minutes ago: |
Bronze Member Username: LeafarPost Number: 21 Registered: Jun-06 | yea it's working |
Silver Member Username: Mc_sunnyPost Number: 146 Registered: Feb-06 | how many channels ? |
Silver Member Username: Hawaiian_timeHawaii Post Number: 510 Registered: Apr-06 | I haven't tried it yet. |
Silver Member Username: Mc_sunnyPost Number: 147 Registered: Feb-06 | tp scan will work ? |
Silver Member Username: Hawaiian_timeHawaii Post Number: 511 Registered: Apr-06 | I would think a tp scan should work. |
Silver Member Username: DjsmithCanada Post Number: 335 Registered: Jul-06 | Dn changes TPs today read my post |
Silver Member Username: Mc_sunnyPost Number: 148 Registered: Feb-06 | thankyou guys ya so tp scan will work. |
Silver Member Username: DjsmithCanada Post Number: 336 Registered: Jul-06 | what receiver is this for |
Silver Member Username: Destine1983Montreal, Quebec Canada Post Number: 129 Registered: May-06 | So far I count 6 ppvs working |
New member Username: GreenappleAngeles, Los PHilippines Post Number: 1 Registered: Sep-06 | i did blind scan and able to receive some ppv. so far i count them 6. scan channels starting 5000. |
Bronze Member Username: MrmeatPost Number: 56 Registered: Jul-06 | works |
New member Username: GreenappleAngeles, Los PHilippines Post Number: 2 Registered: Sep-06 | Yes it is!!! |
Bronze Member Username: Alienloco666Sunrise, Florida USA Post Number: 73 Registered: Jun-06 | Hey Will work with the Pansat 2500a ? Also are you getting DN or VU ? Alien |
Silver Member Username: Destine1983Montreal, Quebec Canada Post Number: 130 Registered: May-06 | I have pansat 2500 clone and it is working |
Silver Member Username: JojogunFairfield, CA United States Post Number: 118 Registered: Apr-06 | I took my 2700 of the shelf...dusted it off..put in all the correct codes and tried the PPV channels. Couldn't get any...so then I tried the VOD channels, and got just about all of them. |
Bronze Member Username: Kirby904Jacksonville, Florida United States Post Number: 24 Registered: Aug-06 | Wow, so what you guys are saying is that Pansat works with PPV right now? COOL =] |
Silver Member Username: JojogunFairfield, CA United States Post Number: 119 Registered: Apr-06 | And oh...forgot to mention...did a blind scan on Echo 8-10 and Echo 7. |
Silver Member Username: Destine1983Montreal, Quebec Canada Post Number: 132 Registered: May-06 | I erased my menu of stations for echo 8 and did a Tp scan to get my stations,otherwise you are just doubling your stations,having ones that work and ones that don't |
Bronze Member Username: Kirby904Jacksonville, Florida United States Post Number: 25 Registered: Aug-06 | I'm currently doing a scan on my Pansat 2700a, i will give an update on weather the PPV or VOD's work. Please give it about 10 minutes. (even though i already ordered 3 Viewsats, and they are coming in lol) |
Silver Member Username: Destine1983Montreal, Quebec Canada Post Number: 134 Registered: May-06 | It's the VOD's that work |
New member Username: AlaindjCiudad de la Havana, Havana Cuba Post Number: 3 Registered: Aug-06 | whit PCI card DVB work??? |
New member Username: BetonmePost Number: 10 Registered: Aug-06 | yep I just got two VODs to work though, not all on my pansat 2700, just do scan. |
Silver Member Username: Oleg1474New port richey, Fl Usa Post Number: 134 Registered: Aug-06 | Thankyou for your advice... my PANSATs still working fine www.ftapalace.com |
Bronze Member Username: Kirby904Jacksonville, Florida United States Post Number: 26 Registered: Aug-06 | Hmm, maybe its because of the rain outside in Jax... im not getting any signal atm so ill just trust that they work. |
Silver Member Username: Destine1983Montreal, Quebec Canada Post Number: 135 Registered: May-06 | Oleg,if your box really was working,why are you online all the time?I would be watching tv if I were you. |
Bronze Member Username: Mexico_2006Post Number: 19 Registered: Jul-06 | whats the bin number, what system is it for |
Silver Member Username: Albino_midgetPost Number: 142 Registered: Jul-06 | if you have been getting locals delete all channels on 110 and rescan works all systems |
Silver Member Username: PrfrmnjPost Number: 155 Registered: Oct-05 | It works with all receivers including Fortec. I just tested PS 2500 2700 and 3500, FLU as well. Dump whatever you had as far as channels on your reciever, load updated keys and do either bling or power scan. You'll be able to pick up so VOD channels. |
Bronze Member Username: Bandulu_dehPost Number: 41 Registered: Feb-06 | Yup Fortec is working. Getting all VOD channels. |
Silver Member Username: Herb_tokerPOTTSVILLE, GRASSLANDS GREEN--LAND Post Number: 203 Registered: Aug-06 | Numbers just rolled but they were working.Guess ill just roll a number till someone posts the new ones. |
Bronze Member Username: Taku420Post Number: 11 Registered: Jun-06 | which Bin you guys are using for FORTEC classic life time? |
Silver Member Username: Herb_tokerPOTTSVILLE, GRASSLANDS GREEN--LAND Post Number: 206 Registered: Aug-06 | 277t |
Bronze Member Username: Taku420Post Number: 12 Registered: Jun-06 | which bin for Fortec lifte time NA??? |
New member Username: DelightfultPost Number: 6 Registered: Aug-06 | Hey I have 119 on Echo 7, used to get 110 on Echo 8, so how do i get all 110 channels again?Whenever i scan Echo 8 all that comes up is the same channels from Echo 7? |
Silver Member Username: DjsmithCanada Post Number: 340 Registered: Jul-06 | you need to have two lmbs to pick up both echo 8/10 and echo 7 one for each sat. |
Bronze Member Username: FfpalmsPalmdale, Florida USA Post Number: 14 Registered: Jun-06 | Check your lnb settings. |
Silver Member Username: DjsmithCanada Post Number: 341 Registered: Jul-06 | 1. Press OK to select ENGLISH language, then press the RIGHT ARROW (twice), to goto ANTENNA SETUP. Press OK. Select the Echo 8/10 satellite on the MENU on the left side, using the UP or DOWN ARROWS. Press OK. *** BE SURE TO SET YOUR DISECQ SETTING to #1 for this satellite to work **** Once you have changed this setting, proceed DOWN to SATELLITE Scan. Press RIGHT ARROW (twice) to ALL. Press OK. The satellite will now re-download your channels. Repeat the steps above for the Echo 7 satellite, and make sure the DISECQ is set to #4 to make the satellite work. You will not see a QUALITY or GREEN signal BAR. This is ok. Please proceed as above. Repeat for any additional satellites that you may have. (be careful to set DISECQ settings correctly) once all satellite sources have been downloaded, you are ready to watch TV. |
Silver Member Username: DjsmithCanada Post Number: 342 Registered: Jul-06 | or try this channels only, please set your DISECQ FIRST ** ** If you have previously aimed your dish, and are now redownloading NEW CUSTOMERS: -> You are already in the ANTENNA SETUP MENU. Select the EchoStar 8/10 (110) on the menu by pressing [OK]. On the right side of the screen your settings should be as follows (without using the DISECQ switch) LNB TYPE: Standard LNB Frequency : 11250 22 Khz: OFF DiSeCq: OFF <- set to # 1 when instructed to do so. SKEW: -45 <--- ignore this setting TP: [ 1 ] 12223 v 20.000 Positioner Settings: Disabled Satellite Scan: ALL Now Press OK to begin scanning for channels. This will go to a new menu, showing TV channels on the left, and RADIO on the right. It is now downloading all active channels to your receiver. We are verifying that you have the correct signal expect to see PCLAS, PELIC channels appear quickly. If not, cancel by pressing EXIT. If the download is correct, allow it to finish. Press exit to return to a full-screen tv channel (not a preview window). You must now power off your receiver (flip black switch on back of receiver to do this or unplug power) before disconnecting the 110 LNB and reconnecting the wire to the 119 LNB. Not powering off your receiver could cause a spark/short circuit and this will void your warranty and could KILL your receiver. Now that you have connected the 119, continue as below: Now Go back into the ANTENNA SETUP MENU by Press MENU to begin your setup. Press OK on INSTALLATION / DISH SETUP, then Press OK on ANTENNA SETUP. Select the Echostar 7 (119) on the menu by pressing OK. On the right side of the screen your settings should be as follows (without using the DISECQ switch) LNB TYPE: Standard LNB Frequency : 11250 22 Khz: OFF DiSeCq: OFF <- set to # 4 when instructed to do so. SKEW: -45 <--- ignore this setting TP: [ 2 ] 12239 <---- This must be set to find this satellite signal Positioner Settings: Disabled Satellite Scan: ALL Now Press OK to begin scanning for channels. |
Silver Member Username: Impala1977Post Number: 101 Registered: Apr-06 | so the keys are? Please. |
Silver Member Username: Impala1977Post Number: 102 Registered: Apr-06 | 00: C3 51 F1 4C B7 24 23 61 CE A4 2D B6 A2 D4 97 E9 01: Active A3 CF 58 E1 50 F6 08 C1 60 90 D2 EA 32 21 06 70 I got this from Keymaster. I am just double checking. |
Bronze Member Username: Taku420Post Number: 13 Registered: Jun-06 | guys, to get VOBs in fortec life time NA, which BIN works? |
Silver Member Username: Impala1977Post Number: 103 Registered: Apr-06 | the latest one from the last ecm. |
Bronze Member Username: Taku420Post Number: 14 Registered: Jun-06 | can you please specify? |
Silver Member Username: Albino_midgetPost Number: 146 Registered: Jul-06 | if you can you watch locals on your fortec just delete all channels and rescan vod are in 5000 |
Silver Member Username: Bazuka2020Post Number: 529 Registered: Oct-05 | Put new keys Delete all channels Blind scan and watch vod channels they are mirror channels of PPV |
Silver Member Username: ZagrosPost Number: 134 Registered: Apr-06 | Nothing is working |
New member Username: ShyiPost Number: 6 Registered: Jun-06 | gone for good |
Silver Member Username: ZagrosPost Number: 135 Registered: Apr-06 | was it working?????? |
New member Username: John_heyPost Number: 10 Registered: Jun-06 | I have a Pantec MX (Pansat clone) did a blind scan and got 6 VOD channels up. Thanks guys |
Silver Member Username: ZagrosPost Number: 136 Registered: Apr-06 | I can't get any. I am in Canada. |
New member Username: GuillermodgPost Number: 6 Registered: Apr-06 | finally some sign of life, yeah 5 ppv working here, in 5000s VODS hope BL get us all pansat viewers a bin. I believe in BL |
Silver Member Username: ZagrosPost Number: 137 Registered: Apr-06 | Can anyone from Canada confirm that. |
New member Username: GuillermodgPost Number: 7 Registered: Apr-06 | I am canadian man Edmonton |
Silver Member Username: ZagrosPost Number: 138 Registered: Apr-06 | Thank you Guillermo |
New member Username: ShyiPost Number: 7 Registered: Jun-06 | Gone from mine re scaning rightnow........ was working while ago. |
New member Username: Bytem3Post Number: 4 Registered: May-06 | please supply the bin for the pansat clone or the keys and steps to update keys |
Silver Member Username: ZagrosPost Number: 139 Registered: Apr-06 | Go to the supplier Rob. |
Silver Member Username: ZagrosPost Number: 140 Registered: Apr-06 | Nothing is working for me. I deleted all put the new keys and blind scaned, but nothing. |
New member Username: FuahMOAMEDQATAR Post Number: 6 Registered: Aug-06 | I have about 7 VOD working, I'm using C00lsat 5000 with bin 1.27. Just re-scan your 110 sat and you will get it (Channel 5817-5830). |
Silver Member Username: Aloha_ainaPost Number: 109 Registered: Jul-06 | Zagros, are you scanning DN birds? |
New member Username: DelightfultPost Number: 7 Registered: Aug-06 | Thanks for all the help!!! Did a blind scan of Echo 7 and got one ppv and another labeled soon2 dont know what channel this is, but it was so glad to have an actual movie on!!! |
Silver Member Username: Herb_tokerPOTTSVILLE, GRASSLANDS GREEN--LAND Post Number: 207 Registered: Aug-06 | Do a blind scan on 8/6 theres a lot more. |
Bronze Member Username: HshakarchiPost Number: 37 Registered: May-06 | So, is it a rule..." for other receivers alike".. if you can watch locals then the bin is ok, "I guess", So if we do a blind scan then we get some PPV . Would this also work on B*V , did anyone test this on B*V. |
Silver Member Username: Herb_tokerPOTTSVILLE, GRASSLANDS GREEN--LAND Post Number: 210 Registered: Aug-06 | YES>>>> YES>>>VODs NO..... |
New member Username: DelightfultPost Number: 8 Registered: Aug-06 | I did all of the instructions, i deleted and reset disques and all that and still every time i scan i get all 119 (my echo 7) even when i do echo 8 with #4 and echo 7 with #1 all same channels come up!!!Before the crash i had both 119 and 110!! |
Silver Member Username: PrfrmnjPost Number: 158 Registered: Oct-05 | Tonya - What type of LNB's are you using? Are you actually using a DiSeCq switch? If you are using DISHPRO LNB's you have to make sure that what you select in your antena setup - NOT - standard LNB... |
Silver Member Username: PrfrmnjPost Number: 159 Registered: Oct-05 | Last but not least, if you are using a switch, you need to make sure you identify the port correctly! ie - 110 to DiSeCq #1 if that's where it's conencted.... |
New member Username: PuchatekPost Number: 1 Registered: Jan-06 | i have pansat 2700a and i had all vod's,but now they gone.Whot is the problem? |
Silver Member Username: HardrockstrikerPost Number: 527 Registered: Apr-06 | I don't mean to sound pessimistic, but I have a feeling Charlie is playing around with PPV to test out a new ECM. No one get alarmed. It's just a hunch. (although I am curious to see how fast VS and C00lsat bounce back after the next ECM). |
Silver Member Username: PrfrmnjPost Number: 160 Registered: Oct-05 | Andy - make sure you have the correct keys. Keys rolled again yesterday. 00 - is still the same, but 01 - changed. Get the right keys and you'll be up again. |
Silver Member Username: ShayeileenPost Number: 112 Registered: Aug-06 | with pansat 2700a i have the 272a bin is this the right one? |
Bronze Member Username: JrqPost Number: 56 Registered: Jul-06 | Yip, the channel moves to a new TP, and it is left unencrypted. Then the next step is to re-encrypt it, but a new version is used. Bam! A new ECM will provide a lot of answers, and will clear the smoke and mirrors. Will VS get back up in a matter of days, as they claim? Will the CS carded solution stay standing? Will PS & others have to start from scratch? Another few months again? The next ECM will provide answers. Open VOD is good news and bad news if you know what I mean. |
New member Username: PuchatekPost Number: 2 Registered: Jan-06 | Thanks PRFRMNJ,but i need new keys. |
New member Username: PuchatekPost Number: 3 Registered: Jan-06 | autoroll on or off? |
Bronze Member Username: BiverlandPost Number: 31 Registered: May-06 | Dish key:00 C3 51 F1 4C B7 24 23 61 CE A4 2D B6 A2 D4 97 E9 01 A3 CF 58 E1 50 F6 O8 C1 60 90 D2 EA 32 21 06 70 ppv not open only vod end plenty of it.... so enjoy for naw.... |
Silver Member Username: Hawaiian_timeHawaii Post Number: 516 Registered: Apr-06 | I agree Jason, looks like DN is up to something. Shay, I saw a list of bins needed and 272c was listed for the 2700. Andy, autoroll off. |
Silver Member Username: ShayeileenPost Number: 113 Registered: Aug-06 | where can i get the 272c i went to future and it looks like it has only 272a?? |
Silver Member Username: Hawaiian_timeHawaii Post Number: 517 Registered: Apr-06 | If your locals are working right now then that bin should be ok. |
Silver Member Username: ShayeileenPost Number: 114 Registered: Aug-06 | yeah they are when i get home im trying it thanks |
New member Username: Bytem3Post Number: 7 Registered: May-06 | i was able to use the last keys for about 15 minutes it froze up i rebooted and nothing looks like they changed the keys again any updates ??? |
Silver Member Username: ZagrosPost Number: 145 Registered: Apr-06 | Can anyone form Canada get these channels. I have pansat 3500sd, bin 353, new keys. I delet and rescaned the birds but I am getting nothing. |
New member Username: Charly_dMontral, Quebec Canada Post Number: 3 Registered: Sep-06 | how can i download that bin 277t |
Silver Member Username: ZagrosPost Number: 146 Registered: Apr-06 | go to Future-fta |
New member Username: Pesar_bPost Number: 1 Registered: Sep-06 | please let me know (any one) how do i get channels in 5000.please please do appreciate it. |
Silver Member Username: ZagrosPost Number: 149 Registered: Apr-06 | Delete all your channels, do a blind serch, and put in the latest keys. It doesnt work for me but it does for otheres. good lock Sam |
New member Username: Bytem3Post Number: 8 Registered: May-06 | Zargos Im in canada and watching VOD as well as other channels i have a clone and used the 277t bin file updaTed the keys and did a blind scan ...seems to be working okay for now had a problem last nite where it froze up on the VOD channels I deleted the VOD channels and rescanned and it came back .Not too sure on your model |
New member Username: DishloverToronto, Ontario Canad Post Number: 3 Registered: Jun-06 | No they are not working at ll. |
Silver Member Username: ZagrosPost Number: 150 Registered: Apr-06 | Thank you Byteme. I finally found it. It was the autoroll. |
New member Username: Bytem3Post Number: 9 Registered: May-06 | no problem but mines down again ..argg |
New member Username: Bytem3Post Number: 10 Registered: May-06 | any new keys ?? |
Silver Member Username: NydasPost Number: 458 Registered: Jun-06 | Go to New Keys thread. https://www.ecoustics.com/electronics/forum/home-video/259083.html |
Bronze Member Username: Bytem3Post Number: 11 Registered: May-06 | thank you Nalin |
Bronze Member Username: Bytem3Post Number: 15 Registered: May-06 | has anyone used this bin on their pansat clone X-85BL_060911_278T_au_api_.bin Did it work it will not work for me ??? |
Gold Member Username: LklivesPost Number: 4372 Registered: Jan-06 | it works great and thousands are using it..U must wait and let the AUTOROLL bring in the new keys! |
Bronze Member Username: Bytem3Post Number: 16 Registered: May-06 | ok i let it go for 5 hours no change this following bit is confusing ::Load new bin then turn autoroll off and set default keys and you will have tv again:: wouldnt you want autoroll on ???? |
Gold Member Username: LklivesPost Number: 4388 Registered: Jan-06 | yes I would want it on with the newer modified older bins like the 278T..otherwise U will have to manually input the keys..its been recommended to shut off the auto transponder (user settings...bottom line) with 278T bin.. |
