Upgrade to 07 Tahoe Bose System
Username: Hmpadilla
Gilbert, AZ
Post Number: 86
Just got an 07 Tahoe w/Bose.Sounds ok,but I'm looking to upgrade a bit.Interested in adding some subs and amps.Can anyone tell me how hard it is to add on or bypass this system?Also where is the amp and sub located? All the bass sounds like it's coming from the dash.Thanks
Username: Big_fletch
Newport, Ar, Ar United states
Post Number: 540
add a jl 1000 watt amp with 2 12 W6's that should sound really good with your tahoe
Username: Juliob
Santo DomingoDominican Re...
Post Number: 2248
^^^^ awesome but too expensive for what it does.. that's my opinion on JL
Username: Makmillion
MN United States
Post Number: 345
I second that, juliob.
You pay for the logo with JL :-)
Username: Longbluesquid
Post Number: 55
JL is definently worth it
Username: Hmpadilla
Gilbert, AZ
Post Number: 87
hey guys thanks for the input,but at this point I'm more concerned with how hard (or expensive) it's going to be to add on or by-pass the Bose system,than I am with what I'm going to put in.Does anyone have any experience with add ons to this system? (amps,subs etc)
Username: Kaerfpl
Spencerport, NY USA
Post Number: 403
bypassing the system isn't hard at all. The hardest part about it is finding where the d@mn factory amp is. After that, all it is is cutting and re connecting the wires.
How much are you willing to spend on subs/amps?
Username: Hmpadilla
Gilbert, AZ
Post Number: 88
at this point I really don't have a budget in mind.I would really just like to keep the factory setup as is and add some subs and another amp.Also I am hoping I can put the subs in the rear side panels since cargo space is pretty limited.
