Gold Member Username: Crayola0Wisconsin Post Number: 1095 Registered: Jun-06 | I have 100 bucks to spend on an amp with wiring...i have two speakers that are 8 ohms and 90w rms...so either a two channel amp that puts around 90 watts rms or a mono amp that puts out 180w at 4 ohms...and i dont use ebay |
Gold Member Username: CtmikeCt. Post Number: 1766 Registered: Feb-06 | don't see you getting anything decent with that amount, try saving more. |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 2343 Registered: Dec-05 | profile! check www.millionbuy.com |
Silver Member Username: BernymacRialto, CA United States Post Number: 223 Registered: Sep-04 | http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=397 Its 150, but to me its the best and closest thing I can find to put out that much. No wiring. You can also probaly get it cheaper off some other sites. |
Bronze Member Username: BrettnicklePost Number: 45 Registered: May-06 | get a kicker zx350.4 and bridge it |
Bronze Member Username: BrettnicklePost Number: 46 Registered: May-06 | http://cgi.ebay.com/KICKER-KX350-4-ZX350-4-CAR-AUDIO-SPEAKER-AMP-AMPLIFIER_W0QQi temZ140027815955QQihZ004QQcategoryZ79823QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
Silver Member Username: CavsmaximaNew York United States Post Number: 229 Registered: Aug-06 | julio i seen that millionbuy ste before they have tons of stuff for cheap. James save some money up and get something good. |
