Silver Member Username: Pike110Post Number: 127 Registered: Oct-05 | I was about to pull the trigger on two SS Rl-p's, but I want to give the FI's a try. I have heard the SS and like them alot, they are about the exact same price shipped. i don't know if I should buy something I have never heard. Has anyone heard the Q's yet? |
Silver Member Username: Pike110Post Number: 128 Registered: Oct-05 | bump |
Silver Member Username: JkidderSpring hill, Florida Usa Post Number: 229 Registered: Nov-05 | they said its comparable to a 05 XXX so if ur basing it on that id say get the Q's. plus scott the owner has been makin subs forever n' im sure u wont be let down. hell im sure i wont either cuz i jus bought the 15 Q |
Silver Member Username: Pike110Post Number: 129 Registered: Oct-05 | Do you think it will have a little more spl than the rl-p's? |
Silver Member Username: JkidderSpring hill, Florida Usa Post Number: 233 Registered: Nov-05 | based on the rms alone i would say yes. rl-p is 500-800 n' Q is 750-1200 according to scott |
Bronze Member Username: 04redmach1Columbus, GA USA Post Number: 95 Registered: Mar-06 | Fi will have lil more SPL, but dont expect the greatest SQ, or a low end monster as well. You should check out the SI BM's they are prob more suited for your SQL needs. www.low-hz.com |
Silver Member Username: Sb2012Iowa US Post Number: 262 Registered: Jul-06 | if you heard the RL-p and u liked it a lot and think its what u want...then get it yes the FI Q would have more SPL |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 5968 Registered: Aug-05 | hey Kevin, are you a low-hz rep?.... |
Silver Member Username: Th3pwn3rChicago, Illinois U.S.A Post Number: 187 Registered: Jul-06 | Kevin's a low-hz rep and he's a very good one,great guy to deal with. |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 5972 Registered: Aug-05 | i thought so. |
Gold Member Username: RedlinerWilmington, Ma Post Number: 2476 Registered: Jun-05 | lol ^^^ muddy |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 5980 Registered: Aug-05 | it just seems to me that the only people(AND THIS IS COMPLETELY MY OPINION) who have anything bad to say about the Fi Q drivers....are theones to are reps for low-hz.....saying the MAg is better better better...for half the price....you got NOTHING on the Q. lol |
