New member Username: WhitewonderPost Number: 1 Registered: Sep-06 | I am working on designing my first system for my 1992 Ford Explorer, looking to get a sub and a component system. My main concern is SQ, but loud is good too, just not at SQ's expense. My budget is about $200-300 for the sub, plus whatever an amp is going to cost me. Any suggestions for this price range? Oh, and I'm thinking 12'' for now unless I can get a good reason to go bigger. Also, I know nothing about boxes, except that sealed is the most accurate sounding (so I guess I would get that.) Where should I go about researching how to build one, or a good place to buy one. |
Gold Member Username: CtmikeCt. Post Number: 1722 Registered: Feb-06 | aa arsenal, si bm, fi q, rl-p. just some to look at that can be bought brand new in that price range. you could also look for a w6. |
Silver Member Username: 420alldaylongPost Number: 155 Registered: Sep-06 | Diamond Audio D6 12" Dual 4ohm 600RMS $179.99 + shipping good clean sub. |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 8952 Registered: Jul-05 | ^^^all the subs ctmike said are better then the D6 |
Silver Member Username: 420alldaylongPost Number: 156 Registered: Sep-06 | But what are the prices on those subs. |
Gold Member Username: CtmikeCt. Post Number: 1723 Registered: Feb-06 | arsenal-$180 plus shipping fi q-$259 shipped si bm-can get for $280 shipped rl-p-$239 plus ahipping |
Silver Member Username: 420alldaylongPost Number: 157 Registered: Sep-06 | Brand new or used because I'm also looking for subs. If they are new where at. |
Silver Member Username: BernymacRialto, CA United States Post Number: 193 Registered: Sep-04 | new, off the dealers website. thats just a guess but most likely the dealer, the rl-p you can probaly get off ROE I think and some other website I saw sold them. |
Gold Member Username: CtmikeCt. Post Number: 1724 Registered: Feb-06 | arsenal http://ascendantaudio.com/index.html fi q https://ssl.perfora.net/www.ficaraudio.com/sess/utn;jsessionid=1544d565ded2f19/shopdata/index.shopscript si bm (talk to ben, showrides here, he'll hook you up) http://www.low-hz.com/ rl-p http://www.soundsplinter.com/ |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 5910 Registered: Aug-05 | mike's gotcha on that one Joey, and why would he be recommending used subs???????? lol |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 8953 Registered: Jul-05 | lol^^^so true.... |
Silver Member Username: Pike110Post Number: 120 Registered: Oct-05 | There is a ascendant audio Avalanche on ebay for 200 bucks buy it now. It has been reconded though. That sub would be pretty good for what you are after. |
New member Username: WhitewonderPost Number: 2 Registered: Sep-06 | $180 - $280 is a big split, also from 500 - 1000 watts RMS. I can tell that everyone on the forum seems to like the FI q's alot, but which would be the best for pure sound quality? Or is it more of a personal taste, and where could I go to research the differences a bit more? |
Gold Member Username: RedlinerWilmington, Ma Post Number: 2434 Registered: Jun-05 | sq is a personal thing but he q is suppose to be awesome if u want the best sq sub lok at he w6v2 |
New member Username: WhitewonderPost Number: 3 Registered: Sep-06 | Bit out of my pricerange as far as I can tell...since I'd only buy from a dealer. I like warranties. |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 5945 Registered: Aug-05 | for pure SQ i would check out the Assassin...the Arsenal is more SQL oriented...even though the assassins will bump. also, check out the Rl-i's if you want pure SQ...you wont need more than 2-300wRMS to fill in the bottom octave |
