2 amps?
Username: Oglejust
Post Number: 115
ok i was wondering... can u put 2 amps to the same sub?
Username: Mygame5982
H-TOWN, TEXAS US
Post Number: 433
yea...same amps??? sure
Username: Redliner
Wilmington, Ma
Post Number: 2436
technically yes safe no unless they are strappable then yes i mean it can be done perfectly fine but all amps work diffrent
Username: Oglejust
Post Number: 116
so they have to be the same amps? you cant mix and match?
Username: Thomas_g
NM
Post Number: 1785
No cuz diff power to each coil will be pushin and pullin differently......1 will be more and 1 will be less, thats y u need tha same amps...
Username: Oglejust
Post Number: 117
but what if its a single coil sub?
Username: Blainew
Post Number: 1516
if its a single coil sub, you need strapable amps..
Username: Blainew
Post Number: 1517
actualy, im not 100 percent sure on that
Username: Oglejust
Post Number: 118
what is a strapable amp???
Los Angeles, CA USA
Post Number: 5484
its bridging 2 amps together so you get the power of both amps in to one sub. you have to have the same amp and also the amp itself has to be able to that. not all amps are strapable.
Username: Redliner
Wilmington, Ma
Post Number: 2437
nope i screwed mself when i first got into car audio and didnt understand that then i had 2 amps i didnt nee and had to buy a new one i wasted like 600 bucks lol
Username: 420alldaylong
Post Number: 181
What kind of amps are you talking about?
