Factory VCR/Monitor setup adding DVD receiver problems
Username: Hzppby
Alright here goes...
Nissan Patherfinder 2001 - factory VCR connected to factory monitor.
Adding JVC DVD receiver, i've ordered everything thinking the VCR has RCA inputs on the front, run the RCA jack from receiver to VCR done.
NOPE, i was told that you can't run a DVD player through the VCR, it works for a second then monitor goes blank grrrrrrrr..
Now screw it, don't want to use the VCR i'll go straight to the monitor, took the monitor off ceiling and it has a nissan special 8 pin plug on it! Can't connect to it!!! Double GRRRRRRRRR!! What should i do now?? or how do i figure out the video input wire to the monitor??
