Help on HDTV's
Username: Zepcoe
Collierville... Us
Post Number: 444
Where is the cheapest place to buy a 27" flat screen HDTV??
Username: Zepcoe
Collierville... Us
Post Number: 445
Username: Riskyb
Post Number: 180
Thats like asking the cheapest place to buy a pickup truck.
It all depends on what you want.
What do you want out of your TV?
How much do you have to spend?
Username: Safe_cracker
Chicago, IL US
Post Number: 1514
No sh!t, lol. I would say try Sam's club 1st then BestBuy. Sony's LCD are the cats @ss, Samsung is also a great unit. Be prepaired to pay out of the wimwam for it, not cheap anywhere! Polo..
Username: Basshead86
Google is your Friend, FL
Post Number: 5904
i saw a Samsung 1080p LCD HDTV with the 1080p Blu-Ray Disc DVD Player with it....UploadUploadUploadUpload
Username: Teddy21
Ann Arbor, MI USA
Post Number: 209
I just got a Magnivox 26in Flat Panel LCD Hdtv for 599.99 from circuit city tonite.
check it out, it has a great picture with the xbox and HD programs but the regular satelite channels are kinda krappy. Its probably because of the cables though, i need to get some nicer cables.
http://www.circuitcity.com/ssm/Magnavox-26-LCD-HDTV-26MF231D/sem/rpsm/oid/145315 /catOid/-12869/rpem/ccd/productDetail.do
Chicago, IL US
Post Number: 1522
Regular sat channels use 1/3 the signal input of an HD signal. The sat HD channels rely on a MPEG4 system that requires three highspeed sat connections, hence the use of either three 18" dishes or one large oval shaped with a tripple LRBN PU system (Direct tv) which works great. If you would have noticed the reviews weren't so great but if you like it, that is all that matters. Polo.. :-)
Username: Kravenblood
Ohio
Post Number: 121
dont buy blue or hd players yet one of em is suppose to go bye bye like bets did
Ohio
Post Number: 122
beta***
