Username: Simikang Post Number: 57 Registered: Jul-06
Wednesday, September 13, 2006 - 00:48 GMT any body know
Username: Lklives Post Number: 4290 Registered: Jan-06
Wednesday, September 13, 2006 - 00:51 GMT any DSS site...and 127 is all the same...just different ones for different receivers like 4000, 5000, 6000
Username: Cucon1 Post Number: 26 Registered: Jul-06
Wednesday, September 13, 2006 - 00:51 GMT www.dsscentral dot net
Username: The_wank_artist Post Number: 1602 Registered: Feb-06
Wednesday, September 13, 2006 - 00:52 GMT any dss site that has files. try dsscentral. net http://www.dsscentral . net/files/ you may have issues trying to get in as traffic is quite high with everyone looking for new bins. you don't need a new bin, you can use an old one and manually enter the keys.
Username: Simikang Post Number: 59 Registered: Jul-06
Wednesday, September 13, 2006 - 00:54 GMT the websites are all down thats the problem
Username: Donnie1973 Post Number: 329 Registered: May-06
Wednesday, September 13, 2006 - 00:54 GMT ftabins.n3t
Username: Simikang Post Number: 60 Registered: Jul-06
Wednesday, September 13, 2006 - 00:56 GMT they dont have the 127
Username: The_wank_artist Post Number: 1605 Registered: Feb-06
Wednesday, September 13, 2006 - 00:57 GMT Sim, You don't need the latest bin, just the correct keys. Wait a day or so and just keep manually entering the keys until the traffic slows down on the site. That is if the channels stay open that long.
Username: Simikang Post Number: 61 Registered: Jul-06
Wednesday, September 13, 2006 - 00:58 GMT but how do i get to the place to enter the keys i cant find it
Username: Chico Post Number: 43 Registered: Sep-05
Wednesday, September 13, 2006 - 01:00 GMT i am using 128 bin on cools@t 4000pro w/ autoroll on, having some glitches. anyone else having the same problem. going to try bin 127 next.
Username: The_wank_artist Post Number: 1608 Registered: Feb-06
Wednesday, September 13, 2006 - 01:02 GMT 8282 on the remote and if you try that link above, I got in. Took a couple attempts but I'm in.
Username: Simikang Post Number: 62 Registered: Jul-06
Wednesday, September 13, 2006 - 01:09 GMT okay thanks guys i got a freind to email it to me thanks alot
