Username: 1tina_chick Post Number: 40 Registered: Mar-06
Friday, September 15, 2006 - 19:17 GMT What are the Advantages to Blind Scan vs. Auto scan ?
Username: Lklives Post Number: 4359 Registered: Jan-06
Friday, September 15, 2006 - 19:18 GMT Blind scan suck with coolsats..
Username: Jahow7 CalcuttaIndia
Post Number: 30 Registered: Jul-06
Friday, September 15, 2006 - 19:19 GMT You can't see what's happening when you use blind scan.
Username: Mike_m Post Number: 16 Registered: Mar-06
Friday, September 15, 2006 - 23:35 GMT LK WHAT SCAN WOULD YOU USE ON A PANSAT 3500??BLIND OR AUTO OR SAT??? THANKS
Username: Fidarahman Post Number: 21 Registered: Nov-05
Friday, September 15, 2006 - 23:43 GMT There is a pre programmed list of channels for all satellites in the box (by the factory). The list includes all on air channel at that time. You may realize that channels keep changing, addind and subtracting every now and then. Now when you Blind scan, all channels as of today come up on screen, while auto scan brings up only those channels which were pre-set at the time of programming by the factory....I hope it clarifies the question...
Username: Fidarahman Post Number: 22 Registered: Nov-05
Friday, September 15, 2006 - 23:44 GMT Always Blind scan to get the latest set of channels.
Username: Xoide007 Post Number: 76 Registered: Apr-06
Saturday, September 16, 2006 - 02:48 GMT If I do blind scan, will this duplicate the channels?
Username: Lroy Post Number: 50 Registered: Aug-06
Saturday, September 16, 2006 - 03:57 GMT Yes duplication takes place for some channels but u can go to channel edit and delete whatever channel u don't want.
Username: Fidarahman Post Number: 26 Registered: Nov-05
Saturday, September 16, 2006 - 16:35 GMT I second
Username: 1tina_chick Post Number: 41 Registered: Mar-06
Saturday, September 16, 2006 - 20:56 GMT Thanks LK You RULE and thanks to ALL, FTA FOREVER !...... Just wait , FTA in HDTV it's not far off !
