Silver Member Username: 2pacalypse1971Sandusky, Oh Post Number: 168 Registered: Jul-05 | i have 2 dual 6 ohm w3's and i knwo i can wire them down to 1.5 ohms but my friends amp that im goign to use is only 2 ohm stable (rockford p6002), so if i run each speaker at 3 ohms, and bridge them, would that be the same thing as 1.5 ohms or would it be alright with teh amps specs...thanks |
Gold Member Username: TjmutlowPost Number: 2810 Registered: Sep-05 | that amp is not stable under 4ohms bridged, if you ran 1 sub per channel, youll get little more then 150 per channel and the w3 do not need a terrible amount of power. |
Gold Member Username: Thomas_gNM Post Number: 1759 Registered: Oct-05 | http://www.the12volt.com/caraudio/boxcalcs.asp Go down to tha parellel/series calcutors |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 2304 Registered: Dec-05 | just get a 800-1000w rms amp at 1 ohm or get PG xenon 600.1 |
