Bronze Member Username: ZeknockPost Number: 13 Registered: Sep-06 | i just got subs and all that and an alpine deck. now i need a bose adapter for the speakers in the car. who has one and wants to get rid of it? or does anyone have any ideas on how to get a cheap one? at circut city it is $100. thanks |
Gold Member Username: SouthernrebelMonroe, Louisiana USA Post Number: 3304 Registered: Mar-04 | check on www.sounddomain.com, they will prolly have one for a much better price. |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 1502 Registered: Jan-06 | I don't even think they have an adapter so you can play your new HU through the stock Bose amp. I did it but I made one. You need to find the color code for your amps input, they are paired and do not use a shielded cable, looks like regular wire. I soldered a set of male rca plugs so it plugs directly into my Pioneer 9800's pre-outs. It works nicely but my out are 5Vs. If you can find an adapter it would be well worth the $100, or just buy an amp, lol. Polo. |
Gold Member Username: TjmutlowPost Number: 2802 Registered: Sep-05 | ebay |
