DTS and Dolby Digital Problem
Mark
I have a Pioneer VSX-D411 reciever. I can't seem to get the DTS or Dobly Digital indicators to come up. Only the Prologic II indicator seems to be working. Any ideas?
Derek
Are you using a digital connection from the DVD player?
Is the DVD input assignable to a digital input (that is VERY important)?
Is the DVD player setup to do Dolby Digital, DTS?
Have you set the movie up in its root menu to output DD, DTS?
Mark
I got it to work. I had to go into the DVD player menu and choose AC-3 Dolby Digital instead of PCM Dolby Digital. For some reason, the receiver does not decode the digital PCM signal. Its sounds great! Thanks for your help!!
Derek
Awesome.
