15 inch sub
Username: Allstar13
Houtson, Texas
Post Number: 53
Is there a 15 inch sub i can get for like 300 dollars that will be as loud or louder and sound as good as 2 12 CVXs and if so wut amp should i get for it thats inbetween 200-400 dollars
Username: Frkkevin
Lake Worth, Texas US
Post Number: 671
www.ficaraudio.com
Marshall White has a 15" RE SX on here for sale that will get louder then 2 12 CVXs.. I think he was asking 210+ shipping
Username: Ctmike
Ct.
Post Number: 1685
you could get a new fi q 15" for $280 or a q 18" for $310, shipped. never heard them, but from reading reviews they've been getting they might be what you're looking for. and if you get one you could give us all a review on it:-)
Username: Ctmike
Ct.
Post Number: 1686
damn, beat me to it!
Username: Frkkevin
Post Number: 672
lmfao .. its ok. But yeah.. FI Audio seems to be the best deal now unless you want to buy used
Username: Allstar13
Houtson, Texas
Post Number: 54
wut amp would be good and how much would the amp cost
Username: Ctmike
Ct.
Post Number: 1687
a 15" arsenal will sound better. don't know if it'll be louder, but it would also be a really good sub. only $250 brand new.
Username: Frkkevin
Post Number: 673
Depends on what sub you get.. do you have a budget? Would be very helpful.
Username: Frkkevin
Post Number: 674
My bad.. did not think before I posted that..
eD Nine.1
Orion 2500d
Hifonics 1606d
Kicker 1200.1
BP 1200.1
...and so on
But yea.. depends on the coil config for your sub
Username: Ctmike
Ct.
Post Number: 1688
scott, the owner of fi, told me to give a 12" q 750-1200wrms. don't know about the 15", but the site says the same rms for both sizes. email him, he's real fast to answer any questions at all you might have. but if it's the same rms you could get a nine.1. probably get a nine.1 for the 12" here soon and scott told me it'd work fine together.
Username: Allstar13
Houtson, Texas
Post Number: 55
ok if i got a Fi Q 15 should i get dual 1 or dual 2 and wut amp could i get that would be good and closest to 300 dollars as possible???
Username: Ctmike
Ct.
Post Number: 1690
depends on the amp. if running at 2ohms, get the dvc 1, if 1ohm get dvc 2. if $300 is all you got i'd check ebay, or the arsenal i suggested before.
Username: Ctmike
Ct.
Post Number: 1691
my bad^^ thought you were talking bout another sub. but the nine.1 is $315 shipped, kicker 1200.1 is about $360 shipped, both brand new.
Username: Allstar13
Houtson, Texas
Post Number: 57
ok so i know there is alot of other things to consider but if i got that 15 with 1000 watts to it with the right box wut would a ruff estamite be on how many decibels i can hit we atleast a decent install
Username: Ctmike
Ct.
Post Number: 1692
135? 140? maybe higher, it really is to hard to tell, especially since i don't think anyone here has actually heard a fi sub.
Username: Allstar13
Houtson, Texas
Post Number: 58
where can i get the nine.1 and which sub should i get for fi q dvc 1 or dvc 2?or if i get the kicker dvc 1 or dvc 2 ill run it at how many ohms yall suggest
and if anybody has heard or is getting one please tell me how it sounds??
Username: Ctmike
Ct.
Post Number: 1694
nine.1 (dvc 1ohm sub)
http://www.edesignaudio.com/edv2/product_info.php?cPath=90&products_id=352
kicker 1200.1 (dvc 2ohm)
http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/1570443/vpcsid/0 /SFV/30046
i'd check with scott on how much power to give it though before getting the kicker, birthsheet with mine says 1490w at 1ohm.
Username: Allstar13
Houtson, Texas
Post Number: 59
ok well thank you veryy much i really do appriciate all the help
