Is coolshat working aswell or just vods?
Username: Poopoohed
Post Number: 11
sounds like panshat is up anyone know about cools situation?
Username: Wakenbake
Post Number: 285
they all should work
pansat and captiveworks that i can vouch for,work
Username: Poopoohed
Post Number: 12
what bin r we to use???
123 124
Username: Wakenbake
Post Number: 286
same bin you have been using (if you updated after the may ecm and are not using the card fix)
Username: Poopoohed
Post Number: 13
yippee wide open again
Username: Nydas
Post Number: 432
All channels up and working with latest Keys and BIN dated 9th June, 2006. ON echo 3( 61.5W) and Echo 8.1 (110W)
Username: Cucon1
Post Number: 22
DN have lifted the ban !!!yippy
