Kac-9152d help!!
Username: Svtmassa
Hey , i had a kenwood kac 9152 d pushing two kicker solobaric 12L5 and they hit hard. Now I have the same amp pushing one jl 10w6v2 and it sounds underpowered??? Whats the deal?
Username: 420alldaylong
Post Number: 13
It should be the other way around the JL should be fine the kickers should sound underpowered. But any ways make sure the ohm load are right.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 2219
^^^^ yeah.. that might be the issue. Also what kind of box did you have with the kickers and now with the jls
Username: Svtmassa
I had the kickers in a sealed box in a lightning, and now i have the jl in a ported box ina crewcab f150
Username: Van_man
Boston South, MA
Post Number: 901
The 2 kickers were probly wire to a 2 ohm load at about 450wrms each. The 1 JL was probly wired for a 4 ohm load at @ 350wrms
Post the amps specs. Im too lazy to research it.
Username: Juliob
Post Number: 2245
Emanuel... l5 and l7s need to go ported all the way bro! ^^^^^ marc is right
Username: Tjmutlow
Post Number: 2785
cant wire 1 w6 to a 4 ohm load, it is a dual 4 sub....
Username: Van_man
Boston South, MA
Post Number: 904
well then its probly wired for 8 ohm, Like I said too lazy to research it.
If ppl posted the specs of equip. it would make it easier for them to get help. That be like me posting, "my system stopped working, What could it be?"
Username: Juliob
Post Number: 2285
^^^^ lol.. i hate those threads
Username: Svtmassa
Post Number: 8
900 watts rms at 2 ohms*** kenwood says..... dont know if its cea rated
Username: Tjmutlow
Post Number: 2799
way more then enough power for the 10w6
Username: Tjmutlow
Post Number: 2800
could it be in the wrong box? they only need a small box...
Username: Svtmassa
Post Number: 11
i bought a box for a 10w7 ported would it make taht much difference? i measured it and it is only a couple inches wider, longer and deeper than the spec one for the 10w6
Username: Juliob
Post Number: 2297
boxes make a big difference... even 1 inch can change a whole sub
