Box carpet
Username: Lowfront
Post Number: 129
Wondering the best place to get box carpet. And how much would I need to a single 10inch box sealed.
I see crutchfield has some for 30bucks. I don't know should I just go with that seeing I need to get a couple things from there.
Also where should I get the speaker terminal for the sub? Crutchfield again?
Username: Splmonster
Nowhere, OH USA
Post Number: 414
go to ur local shop, easiest, i wraped my 3.5 box for 20 bucks and had some left over to play with
Username: Lowfront
Post Number: 130
I'm looking at partsexpress they have some cheap stuff, but need to know how much I should get they have it 40inches wide, by the yard.
Username: Stnorris
IA US
Post Number: 1281
i once heard from a wiseman. carpet is carpet. just like wire is wire..
Username: J_baby15
Kentucky
Post Number: 564
I disagree^^ If you've ever used the cheap sh!t from autozone you'll understand. its like 5yds for $10 and its rediculously thin, you can see thru it when u pull on the sides.
Username: Gangstafert
Jacksonville, Florida USA
Post Number: 301
Dont mean to interupt but is there an online tutorial on carpetting boxes if not could anyone help me out. Thanks.
Username: Dustin3
Tigard, OR U.S.
Post Number: 3410
not really. bcae1.com has a section on box carpeting. i have been learning myself :-)
and carpet is not capret, usually the cheaper stuff is thick and not very flexible meaning its hard to get around the edgesof the box. Good quality carpet is thick but its very flexible. just go to ur local cau audio shop, it will be cheaper than buyin onine.
Username: Stnorris
IA US
Post Number: 1283
jordan...this is the wiseman i heard it from.
DD Naz*i (9:30:12 PM): hahahaha
DD Naz*i (9:30:17 PM): carpet is fu*cking carpet
DD Naz*i (9:30:25 PM): hahahahahahaha
lol if you can see through it, it wasnt carpet. lol.
Username: Stnorris
IA US
Post Number: 1284
DD Naz*i (9:33:41 PM): invite him in here bro. carpet s f u c k i n g carpet.
Username: Dustin3
Tigard, OR U.S.
Post Number: 3411
lol. yes, if you can see throgh it, its not carpet. but the flexibility of the carpet is very very important. and chaper carpet has barely any flexibility. i have touches and bent 3 diff carpets for boxes in the last three days. and two of them you couldnt use, because they were not flexible
Username: J_baby15
Kentucky
Post Number: 565
Lol. good point steven. But when it was in the plastic it looked alright. It said factory replacement carpet, so i figured itd match my factory carpet, which it did, but suckd. Is there no vids or anything that you can DL to teach u how?
Los Angeles, CA USA
Post Number: 5385
you can pick up a 4' x 15' black carpet on ebay for $30 shipped.
Username: Rovin
Trinidad & T...
Post Number: 9038
i have 2 disagree on carpet is carpet
available locally where im from we get 2 kinds of box carpet - 1 type has rather compact fibres & is a lil bit more stiifer , other type the fibres r a bit more loose/furry , the furry kind obviously has a different texture BUT the biggest problem with it is that it soaks up more contact cement when u apply it but it is also a bit more stretchy than the other type - i prefer the more compact lil bit more stiffer carpet , but either works just as fine tho .......just my 2cents here ...
Username: Rickeyd87
Post Number: 90
http://www.klausaudio.com/shop/box-replacement-parts.cfm
check out that site for your carpet.
Username: Talon_es93
Trinidad, Co
Post Number: 369
i've used flexstone on a box before and i thought it looked bad azz....spray it on let it dry and a little sandin and then a clear coat...good to go
Username: Basshead86
Google is your Friend, FL
Post Number: 5771
USE COMMON SENSE.....
if it looks like it is too thick or too thin....don't buy it.. WTF???? lol:-O
Los Angeles, CA USA
Post Number: 5397
rofl.
end of thread.
