Silver Member Username: BernymacRialto, CA United States Post Number: 120 Registered: Sep-04 | Well this is somewhat of an Estimate of my upcoming car audio system. 2 HD315s 750 1 RFT4000 or Two MA P3000 1500 High Amp (MA or RF) 300 cdt ES 620 from AlterAudio 650 pioneer 960mp (from Mick) 250 Custom Ported Enclosure 250 4 yellow top batts(170 Each (suggestions? 680 HO ALT (Not Sure How big I need to go) 350 4730 Estimated. Bad?Good?Okay? I already Ordered the HD3's and Theres no turning back on this setup. I have to even pay more since I need wires/and probaly a bigger alt or two alts. Whats your input? Any thing you would probaly change? Suggestions are welcome. If you know where I can get better prices for the batteries, amps, or whatever is appreciated. |
Silver Member Username: DrsmithMontana USA Post Number: 491 Registered: Nov-04 | get red tops unless you play ur system with the car off alot looks really good i'm so proud of myself startin up this audioque buzz lol yay me i'm number 1 |
Silver Member Username: BernymacRialto, CA United States Post Number: 122 Registered: Sep-04 | No, I play my audio only with my car on. To many bad things have happened with my car off. So red tops are better if your going to run your car? Yellow tops are better when your car is off? |
Silver Member Username: BernymacRialto, CA United States Post Number: 123 Registered: Sep-04 | Oh yeah DOC, did you find out which amp you wanted to use yet? I'm still undecided. |
Silver Member Username: DrsmithMontana USA Post Number: 492 Registered: Nov-04 | well i think what DJ was sayin about MA amp is that it isnt the best for comps but it should be cool so i think i'm gonna run the MA P3000.1 with my one 15 |
Silver Member Username: Mr_keboAlbertville, Al USA Post Number: 454 Registered: Nov-04 | maybe i need to look into this brand. whats the webpage for them |
Silver Member Username: DrsmithMontana USA Post Number: 496 Registered: Nov-04 | www.audioque.com |
Silver Member Username: DrsmithMontana USA Post Number: 498 Registered: Nov-04 | also berny the alt will be more than 350 but if ur lookin to spend that much then it shouldnt be a big deal |
Silver Member Username: BernymacRialto, CA United States Post Number: 124 Registered: Sep-04 | True, I just ordered me some CDT HD-62/M6's two sets. So I got two things checked off my list, whew. I need major help on amps for my components. I need something like 200rms x 2 at 4ohms. EDNINe 2x has one but are they good? And I would prefer to have my amps all the same. And is there a different in the sounds of front and back? I know there is for left and right. |
Gold Member Username: InvainMichigan United States Post Number: 4115 Registered: Aug-04 | If you have the money to spend, get the yellow top. It's intended for vehicles with high current draw. The red is still much better than any regular brand battery, but your spending 4k on your system. Spend the extra 50 bucks and get the Yellow top. |
Gold Member Username: RedlinerWilmington, Ma Post Number: 2359 Registered: Jun-05 | get a red top for the starter battery and yellow tops for the ones n the trunk or whereever your putting them and bt want to send me some money lol |
Silver Member Username: DelsolePost Number: 852 Registered: Feb-05 | 4 batteries |
Gold Member Username: InvainMichigan United States Post Number: 4127 Registered: Aug-04 | = not necessary. You could go with a red top for starting and a dedicated yellow for your system. Optima batteries are completely sealed, so you could mount it somewhere in your trunk without worrying about fumes. |
Silver Member Username: Atllefty12FL. Post Number: 368 Registered: Jul-06 | DRSMITHHD3, The best amp I personally can recommend for a single HD3 is the RF T20001BD, you can purchase a refurb. from ebay for $600. As for you Berny, I just hope you know what you're getting yourself into. 2k watts is loud, but 4500 could hurt you, especially on effiecient motors such as the AQ's. Good luck, keep us updated. |
Silver Member Username: BernymacRialto, CA United States Post Number: 130 Registered: Sep-04 | Yeah I just came back from ROE watching some videos of the DD9515's because the HD315s compare to them must closer and HD315's is what I'm getting. After watching a Video of two DD9515's powered by one 2500RMS orion amp, I GOT THE CHILLS!!! I thought to myself, damn this is probaly too much. But would it be okay for my just to turn the bass down and slow increase it on my HU when I get used to the old config. Would that be safe or not? But I will have to see still. I will keep everyone updated as time goes by. |
